Go to Post You can expect to see the the same old same old again this weekend! Another set of fantastic experiences for thousands of kids across the country. And once again, Mission Accomplished. - Aidan F. Browne [more]
Unread 22-01-2012, 13:37
keatiyeh175's Avatar
keatiyeh175 keatiyeh175 is offline
Alumni of FRC175~Mentor for FRC2342
AKA: Kelsie A
FRC #0175 (Buzz Robotics)
keatiyeh175 has a spectacular aura aboutkeatiyeh175 has a spectacular aura aboutkeatiyeh175 has a spectacular aura about
Question Ball Texture
Upon recieving the balls in the KOP, we've noticed that some of them are harder, or less squishy, than the others. We'd like to know if this was supposed to happen and it will be that way on the field in competition or if it's the manufacturer's fault. Thx(:
Go Buzz!
Unread 22-01-2012, 13:40
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: Ball Texture
I noticed if you rip the cover a little, accidental testing incident, any memory like effect the ball has goes away. Not sure if that what your noticing.
Every day is a new adventure!!!
Unread 22-01-2012, 14:35
Joe Schornak's Avatar
Joe Schornak Joe Schornak is offline
No Stranger To Love
FRC #2840 (Blue Tide)
Joe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to behold
Re: Ball Texture
It would be wise to design your manipulator to account for variability in the balls, just in case.
1. Acquire Manual
2. Read Manual
3. ???
4. PROFIT!
Visit www.pcdsrobotics.org!
Unread 22-01-2012, 19:24
TheAthlete TheAthlete is offline
AKA: Adam Talajkowski
FRC #0930 (Mukwonago B.E.A.R.s - Building Extremely Awesome Robots)
Team Role: Electrical
TheAthlete is an unknown quantity at this point
Re: Ball Texture
We have the same problem. We noticed the basketballs we got in the KOP were less squishy than the ones we ordered from first choice (those are almost memory foam like). Since we havent really heard of any other complaints, we're going to assume the KOP basketballs are the competition regulation, if thats safe to say.
Doesn't really make sense though, usually FIRST mass orders all of the games pieces, so why they're different is just weird.
Unread 22-01-2012, 19:44
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: Ball Texture
Originally Posted by TheAthlete View Post
we're going to assume the KOP basketballs are the competition regulation.
It might be a good idea not to assume anything.
You can be SURE that the balls will behave differently in the competition in the sense that no two will behave EXACTLY the same.
They WILL have rips, cuts, dents and other irregularities and they will probably not be replaced until they become almost unusable.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 22-01-2012, 19:46
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Re: Ball Texture
Variation is what you have to live with in the FIRST games. That's the way real life works too. Design robots accordingly.
In 2009 the balls would break and we had to test to see if our mechanisms would accept a broken ball.
Last year wasn't so bad, but the tubes weren't always blown up to exact dimensions (either at competitions or at home). They would pop too.
If you've got a spinning-wheel shooter, see if you can compress the balls enough that the difference in squishiness doesn't matter (or if normal compression works like this anyways). I'm guessing that this will work. (But don't take my word for it.)
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 22-01-2012, 22:40
evoluti1's Avatar
evoluti1 evoluti1 is offline
AKA: Joe
FRC #1197 (TorBots)
evoluti1 has a spectacular aura aboutevoluti1 has a spectacular aura about
Re: Ball Texture
We've hypothesized that this difference in behavior is due to the air-tightness of the ball's outer surface. If you take a brand new ball and squish it all the way, the air rushes out and takes time to find the few holes in the ball's skin as it rushes back in. However, an old ball with cuts and tears in it appears to bounce back because the air can rush in faster.
If you're going to assume anything, assume they'll bounce back. Our guess is that they'll probably all be like that after the first match (definitely after Thursday at competitions). However, it's better not to assume anything. Different balls will have different surface features, even older balls may be slow to bounce back also as the foam wears out. It's best to build a ball-ejecting mechanism that doesn't care how fresh or messed up the balls are.
Hope that helps!
Unread 23-01-2012, 11:08
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Ball Texture
Don't. We got both types in the Kickoff KOP. It doesn't seem to be solely and wear and tear issue, though that certainly contributes. We have several balls that, while provided by the KOP and/or FIRSTChoice are very obviously manufactured differently to the point of different densities, surface finishes (sheens, hardnesses) and manufacturing hole methods.
