Go to Post This is what I love about FIRST everyone helps and asks why later. - Kyle [more]
Unread 22-01-2012, 17:18
G33K's Avatar
G33K G33K is offline
Professional Baller
AKA: Ethan Anderson
FRC #0100 (The Wildhats)
Team Role: Electrical
G33K is on a distinguished road
Flat 12AWG Wire Legal?
For various reasons I am looking into using flat 12AWG wire to drive the two motors for our shooting mechanism. I have found no rules thus far that prohibit the use of flat wire, as long as they are the appropriate gauge for the application [R44]. Additionally, the lack of color coding on the flat wire is not an issue as pointed out in [R45] because the output from the Jaguar is not necessarily constant polarity (granted we'd still mark the wires for reference).
Here's the wire I'm looking at: http://cableorganizer.com/flatwire/audio-cable.html (P/N FTW-55921201)
Is there anything I've missed that prohibits the use of flat wire? Thanks
Unread 22-01-2012, 19:26
Team 4057 Team 4057 is offline
FRC #4057 (Klamath Basion Robotics)
Team 4057 is an unknown quantity at this point
Re: Flat 12AWG Wire Legal?
I don't think it is, the problem is the fact it is not color coded. even if there is no set polarity I would still be wary. you are right the rules don't prohibit the use but in past competitions inspectors vary so one might pass you and later you might get dinged. So I guess it is legal but I would still check with the GDC for an official ruling
Unread 22-01-2012, 19:29
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Either way this stuff is very cool.
Every day is a new adventure!!!
Unread 22-01-2012, 19:32
Jim Wilks Jim Wilks is online now
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Assuming it is legal, a couple of other concerns should be noted:
1) At $2 to $3 a foot, this stuff is quite expensive.
2) If you have problems with it at competition such as open or intermittent connections, how are you going to troubleshoot it?
Unread 22-01-2012, 19:33
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
I'd agree that the stuff is cool, and I can relate as to the uses on a competition robot, but we have had experiences where we used 18AGW wire that was white and yellow, and got rejected by an inspector. Not a huge issue, we just swapped out for red and black at the competition. If you can avoid it, I'd suggest you do simply to avoid complications in the future.
Academic Student (Forever)
Unread 22-01-2012, 19:43
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Yellow wire is illegal per [R45].
The lack of color coding is an issue because color coding is required as per the connection it's used for, not the polarity of the power flow.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 22-01-2012, 19:47
Do you have a rule to support this? Wire that can change polarity is expressly exempt from R45.
Unread 22-01-2012, 19:53
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
True, but [R45] also says;
All active circuit wiring with a constant polarity (i.e., except for outputs of relay modules, speed controllers, or
sensor outputs)
shall be color-coded as follows:
I think that little bit rules everything else out. Having been an inspector last year, we were instructed to make sure everything was color coded in a consistent manner, and we checked the path of most major wiring (speed controllers and such)
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 22-01-2012, 19:54
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
R-45 requires color coding only on the power side of the speed controller or relay module. On the motor side of the controller, you may use whatever colors you want since power is passing in both directions. Past the controller there is no consistent + or - to deal with. Both students and inspectors often get confused about this.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 22-01-2012, 19:57
AKA: Scott
Dr. Bob
I'm well aware of that fact sir. I miss read the OP, my bad.
Unread 22-01-2012, 22:11
How do you intend to connect this stuff to the speed controller and the motor?
Unread 22-01-2012, 23:29
G33K's Avatar
Professional Baller
AKA: Ethan Anderson
I think it's possible so scrape off the insulation and solder on a short length of standard 12AWG wire on each end for connections. In any case, it is unlikely that we'll be using this stuff as plans changed shortly after I posted this thread. Still a useful discussion, though, for sure.
Unread 23-01-2012, 08:07
Sorry I didn't see this post earlier. There is nothing illegal with this wire being used on the robot. While it is not color coded and can be used on the output of controllers, there must be some marking on it indicating polarity. I am often cautious of using "audio" wire as many companies over state specifications. What may be termed #12 may in fact merely act similar to #12 in this application. Robot wire specifications are taken from the NEC handbook for open (not in conduit or confined spaces) wiring. Another thing I would consider when looking at this wire is it's survivability on a moving robot. Bends over structural metals could breakthrough the outer cover exposing the conductive material inside.
Unread 23-01-2012, 10:09
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
I believe you can't even cost it by the foot unless you can BUY it by the foot. The shortest spool is 25' @ $75. You would have to cost it at $75 even if you only used 6".
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 23-01-2012, 10:23
EricH EricH is online now
- Bryce
Per unit cost (per foot, per lb, per inch) is a standard cost comparison tool. Instead of saying, let's say, 25'/$75 for flat versus (making up numbers here) 100'/$50 for normal, you can just say that it's $3/foot versus $0.50/foot.
By the rules, yes, you're correct (though many places will cut bulk items for you and sell at a per-foot rate). But what you missed was the implicit cost comparison to normal wire.
