Go to Post If you have not had a positive experience in FIRST, please don't bring those that have down. - Jeff K. [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 20-01-2011, 20:48
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Re: CAN Cables
Only connect the two center pins. Pins 3 & 4. If you connect them all, one is a ground connection and will create a ground loop. The only signals needed are the CanHigh and CanLow. This is a balanced differential circuit, so no ground connection is required.
If you have a ground loop and one Jaguar has a heavy load and another does not this situation will cause noise. We smoked several Jaguars last year and after we disconnected the ground connection the system was much more stable.
The only cable that needs the ground pin connected is the serial cable that connects to the cRio or computer. The ground wire would only be required on the first Jaguar if you are using the serial port as your CAN gateway. If you are using a 2CAN or other outboard device then only connect the center two pins.
Be sure to have the 120 ohm terminator at the end of the line.
-Hugh
Unread 20-01-2011, 21:20
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: CAN Cables
actually, for robotics use, TI recommends 100 ohm resistors, not 120. see the jaguar manual
every document i have read has said to use all 4 connections. if they did not want all for they would have used only 2 pin connections on the jacks (they make them like that as i see computer modems with them all the time). they instead used four. if it was such a bad problem, they would have left them out.
just my personal opinion...
Unread 25-01-2011, 19:58
eStop Robotics's Avatar
eStop Robotics eStop Robotics is offline
Partner, eStop Robotics LLC
AKA: Joe Troy
eStop Robotics has a spectacular aura abouteStop Robotics has a spectacular aura abouteStop Robotics has a spectacular aura about
Re: CAN Cables
Greetings from eStop Robotics!!!
We have CAN cables to connect your Jaguar Speed Controllers to your cRio! We can supply you with terminators, the Serial to CAN interface cable, 12 inch, and 36 inch CAN cables.
http://www.estoprobotics.com/estore/...d&productId=34
These cables are great for making the CAN communications work in your FRC Robot!
Good Luck to all the Teams!!!!!!
Unread 15-01-2012, 14:55
blu28 blu28 is offline
FRC #0151
blu28 is an unknown quantity at this point
Re: CAN Cables
I misread the pinouts and ended up connecting all 6 pins. I have the pairs connected from the outside in, which is to say that one pair is on pins 1 and 6, reversed so that the wire on pin 1 on one end is connected to pin 6 on the other and vice versa. Likewise there is a pair on pins 2 and 5 and also one pair on 3 and 4. Does it hurt to have the extra pair on the outside? What about wiring the one marked at no connector that corresponds to the ground?
Unread 15-01-2012, 20:38
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: CAN Cables
I assume you are trying to make cables for to communicate between Jags and not a serial adaptor. Below is a link to a thread with a video tutorial on making CAN cables.
I hope this helps.
http://www.chiefdelphi.com/forums/sh...an+cable+video
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 15-01-2012, 20:41
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: CAN Cables
You may also find the CAN guide and video on my team's site helpful:
http://team2168.org/index.php/resour...10-can-jaguars
http://team2168.org
Unread 22-01-2012, 11:36
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Originally Posted by Geek 2.0 View Post
Did you just leave 2 of the wires unconnected? Sounds like an awesome idea!
I'm at a loss to understand how twisted pair helps you when CAN doesn't use a differential pair and 5e isn't shielded...
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 22-01-2012, 14:49
Re: CAN Cables
- Bryce
CAN does measure the voltage difference between CAN high and CAN low, this is why it is used in HIGH noise environments such as automobiles.
Mike Copioli
Unread 22-01-2012, 22:24
AKA: Joe Troy
Re: CAN Cables
The decision is often...buy it or build it?
Given the limited amount of programming and development time during the robot build portion of the FRC season, it makes sense to focus on the implementation of CAN in a robot design rather than spending time fabricating cables.
Building CAN cables is not rocket science but it is one more thing to do on a long list of tasks in a typical robot build.
If you decide to build it...see the Texas Instruments website for Stellaris Jaguar CAN information.
If you decide to buy it...see the eStop Robotics website for CAN cables inclduing a CAN Starter Pack.
Either approach will give you access to the advantages and features of a CAN enabled FRC robot.
Unread 23-01-2012, 08:25
Re: CAN Cables
Good advice you may also visit:
http://www.andymark.com/product-p/am-0967.htm
http://www.crosstheroadelectronics.com/Cable.html
Andymark has a do it yourself kit, CTRE has both premade and do it yourself along with a video on how to assemble your own cables.
Mike Copioli
Cables MHSrobotics2853 Technical Discussion 4 19-01-2010 12:14
PWM cables... Where can i buy them??? M. Gildner Electrical 10 11-02-2009 12:31
Y-cables fishgurl Electrical 4 01-02-2008 23:48
Can we shorten the PWM cables? RAWdealer59 Electrical 3 18-02-2003 15:49
No cables? archiver 2000 5 23-06-2002 22:43
