Go to Post I didn't think it was possible for Dave to be any more cryptic. I was wrong. - IMDWalrus [more]
Unread 22-01-2012, 23:24
Re: Eclipse Vs. NetBeans
While it sounds like shuhao may have experience with both IDEs outside of FRC, I think you also need to consider how well they work with the FRC plugins. It seems that this year, netbeans is updated faster, and also has many more users. Given that the FRC build season is so short that the ability to get support would probably be towards the top of features I was looking for.
Unread 22-01-2012, 23:48
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
You're absolutely correct. However it would seem the only things that really matter is the sunspotsdk files, and a couple of ant build files.. which can easily be pulled and pushed into the eclipse installation in case there's an update.
At the end of the day, it's just an ant build file
Unread 23-01-2012, 00:04
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
We've had no issue with autocomplete in netbeans. Could you clarify when you are having an issue with it performing properly?
Unread 23-01-2012, 07:58
Sorry. I meant auto save actions. Also things like auto import .. etc.
I use Netbeans as my preferred IDE. When I want to throw together a quick java GUI, you can't beat it. And by the way, there are plug ins for it.
As far as IDEs go, I haven't had too much experience with many others (I usually only program in java, and most IDEs are for other languages. I feel a bit like a tourist). I've used MPLAB, Matlab, JCreator, XCode, Codewarrior and Bloodshed before, and I've played around with Labview, Codewrite and Eclipse.
I suppose I could say I also have used notepad, gedit and VI from time to time, but you could hardly call those IDEs.
My advice is to find something you like for the application/language you're writing, become proficient with it and stick to it. It helps when either it is the language's standard, or has a large user base along with plug-ins.
My preferred IDE is no IDE. The main editor I use is geany, and secondary is vim, where geany I use for larger projects, and vim I use for 1-2 file projects. I would say I'm rather proficient in geany and vim.. but then both are just text editors.. not much to learn (vim people please don't hate me for saying that..)
I use eclipse when I have to write Java (because Java is an eclipse proprietary language, amirite? ) due to the fact of the massive amount of options in eclipse, so I can customize it to my needs relatively well (take the time to go through every single options in eclipse.. then do the same for netbeans.. then you realize why eclipse is much much superior), but the IDE is still slow and bloated ("Let me get some coffee while I wait for Eclipse to redraw it's main GUI")
That being said.. It's just my opinions, and I have very very strong opinions over these kinda things.. (maybe I have OCD? not sure..)
Unread 23-01-2012, 08:12
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Use whatever IDE integrates best with the language and tools you are using, and you are most comfortable with.
I've worked with graphical languages which are their own IDE's (LabVIEW/Simulink), and IDE's like MATLAB, EasyC/RobotC (VEX), MPLAB (IFI/VEX), Eclipse (Android dev), Notepad++, and others. I've also worked with just gedit to write a lot of fairly simple Perl scripts.
I never really felt that any one of the above editors was limiting me except for EasyC (that editor as a text editor is awful). In most cases, I used the editor I was given or the editor that worked with the build chain. In many embedded cases, the build chain is designed to work with a single editor, or even integrated directly into the editor, so you use what you can.
Kettering Motorsports
