Go to Post You can either spend lots of energy complaining about it and whining or you can try to figure out how to make a positive experience from the whole thing. - dlavery [more]
Unread 23-01-2012, 07:21
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Kit Chassis
Originally Posted by squirrel View Post
We have part of our ball manipulator stuff on the kit chassis, but we're planning to make a custom chassis. The kit chassis won't work for what we want to do, and we've built a custom chassis every year except last year (and the kit chassis does have a design flaw that we didn't anticipate, and led to our robot failing in eliminations).
I guess what you need to do is figure out where you are, and where you need to be, and decide if you can get there using the kit chassis, or if you need to do something else. Also consider just modifying the kit chassis, making kind of a "hybrid" chassis that uses as many existing parts as possible, but new parts where needed to make it work.
Another thing....we try to make the "upper" part of the robot as light as possible, and we don't worry much about how heavy the chassis is, within reason. Our first year, we had a top heavy robot, and learned the hard way about center of mass.
This year we plan to make another steel chassis, it's pretty entertaining watching people see it and shake their heads in disbelief
What is/was the design flaw? I am very interested to learn what the flaw was and how it impacted your robot.
Welded steel chassis? Approve!
OP: the kit frame is probably more than adequate for what you want. My team will be using a customized kit-frame, welded together to save the weight of the kit fasteners (~3lbs).
Unread 23-01-2012, 07:40
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: Kit Chassis
The flaw* with the kit chassis is the length of the axles between supports (the two c channels) makes it susceptible to damage from hard vertical impacts on the wheels. Two possible fixes for this are to increase the axle size to 1/2" or to move the two c channels closer together (reducing the bending moment on the axle from any given load on the wheels).
*Flaw in this case refers to a structural limitation, not a fatal mechanical design oversight.
