Go to Post "Pimp my shopping cart"?!?! - dlavery [more]
Unread 21-01-2012, 18:06
ConcreteKahuna's Avatar
ConcreteKahuna ConcreteKahuna is offline
AKA: Bryan
FRC #4128 (Singularity)
ConcreteKahuna is an unknown quantity at this point
Quick question
Hey guys, rookie team here.
We hjust have a quick question to confirm something. Are we allowed to cut down our frame to be smaller than the two possible set-ups from the andymark kit that was given to us. We see nothing against it in the manual but we just want to double check before we cut
_______________________________________________
Team 4128 Holmdel NJ
Unread 21-01-2012, 18:07
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Quick question
You can but remember that you can't add metal back to it!
Measure thrice and think very carefully before you cut your kit chassis up into little bits.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 21-01-2012, 18:08
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Quick question
Yes it is legal to make a robot smaller then the 28x38inchs.
So feel free to cut away, but remember think twice cut once...
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 21-01-2012, 18:22
AKA: Bryan
Re: Quick question
Thanks to both of you
Unread 21-01-2012, 23:19
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Quick question
You definitely want to avoid using a 28x38" frame. Go for 27x37 at the largest.
The reason is that bolt heads and such will be a problem as well any 'out of square conditions in your robot. As rookie team, you haven't seen the 'sizing box' -- this is a 28x38x60" box, that your robot has to fit into, or you don't get on the field.
Good luck, and welcome to FRC!
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 22-01-2012, 09:38
Re: Quick question
Brian,
If you are using the kitbot frame kit you must cut it. The parts exceed maximum dimensions for the robot. I recommend that all cuts be made planning for a frame that is 1/4" smaller in all dimensions. That should give you a frame that is at least 1/2" under the max dimensions allowed and gives you an opportunity to add hardware that you have forgotten previously.
This is one of the most common rookie mistakes.
[R02]
The Robot must satisfy the following size constraints:
A. horizontal dimensions must not exceed 28 by 38 in.,
B. the absolute height must not exceed 84 in.,
C. the height of the Robot at the start of the match must not exceed 60 in.,
D. any appendage may not extend more than 14 in. beyond the frame perimeter, and
E. no other part of the Robot may extend beyond the vertical projection of the Frame Perimeter (with the
exception of minor protrusions permitted per 0).
Unread 22-01-2012, 10:25
tsakshaug tsakshaug is offline
FRC #0340
tsakshaug is an unknown quantity at this point
Re: Quick question
As we like to say.
Think
Discuss
Think
Measure
Have someone else measure
Measure
Cut
Unread 23-01-2012, 07:47
Re: Quick question
Originally Posted by PRich1477 View Post
This was a legal robot in 2008, and as you can see, you could still do this if you wanted to (although the bumper rules have changed a little). Here's a video of it in a match (yeah, QuickTime, sorry).
This was not a legal robot in 2008 as deemed by the GDC later. It is not the size that made it illegal though. The bumper rules have changed, in minor ways, for this year only.
Unread 23-01-2012, 10:58
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
Re: Quick question
What made that robot illegal?(curious)
Unread 23-01-2012, 11:01
Re: Quick question
IIRC, it was determined to be two separate robots (due to the bumpers). This determination caused much confusion as there was no clear definition of robot that particular year (well, there was... but that's a whole nother story).
Search "Speed Racer" on CD and you should find more of the story. That picture is missing the other half of the robot.
Unread 28-01-2012, 23:15
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: Quick question
Wow - amazed to see that "Speed Racer" still lives on in the memories of those on CD...
Video of "Speed Racer" running in an off-season tournament can be seen on the 1519 videos page in the "2008 season" section: http://www.mechanicalmayhem.org/teamvideos.asp
Direct link: http://www.mechanicalmayhem.org/vide...TB-13-Laps.mov
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
