Go to Post Sally Ride says role models are needed - that's you. - JaneYoung [more]
Unread 21-01-2012, 13:19
AKA: Brad
#0190 ( Gompei and the Herd)
New Vision sample program
There is a new vision sample program included with the latest update of WPILibJ (just posted on the update site). Also, in the WPILib project, Documents section, there is a paper describing how it works. In addition, also in the Documents section, there are some sample images to play with and a Vision Assistant script that was used to create the sample code.
Please provide some feedback on this sample and the paper.
Brad
Brad Miller
Robotics Resource Center
Unread 21-01-2012, 18:16
adf0221 adf0221 is offline
FRC #1517 (Lumberjacks)
adf0221 is an unknown quantity at this point
Re: New Vision sample program
This has already helped us a lot. Our team had been struggling for quite a while trying to figure out how to track but the paper and the sample code simplified it drastically! Thanks a bunch!
Unread 21-01-2012, 21:51
jrutten jrutten is offline
FRC #3189
jrutten is an unknown quantity at this point
Can you please provide a link to the update site you are referring to?
Thanks
Unread 21-01-2012, 22:15
nonamedude nonamedude is offline
FRC #1815
nonamedude is an unknown quantity at this point
There was a thread about this but here http://firstforge.wpi.edu/sf/frs/do/...e ans_modules
Unread 21-01-2012, 22:34
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
I've found the sample code but I can't find the document. Could someone provide the link?
Edit: Never mind, found it at http://firstforge.wpi.edu/sf/go/doc1304?nav=1
Unread 21-01-2012, 22:51
FRC #3189
Will the Eclipse plugin be updated, too?
Unread 21-01-2012, 23:32
Jared Russell's Avatar
Taking a year (mostly) off
Thanks, Brad - this is very helpful. We are still in the process of figuring out whether we want to do onboard or offboard image processing, but at least with this update, doing it onboard is a viable option!
Unread 22-01-2012, 13:02
rockytheworm's Avatar
rockytheworm rockytheworm is offline
AKA: Chris Kirk
rockytheworm is an unknown quantity at this point
If we use a red led ring, the sample code should work, correct? There is nothing we have to change for it to run correctly? We are having some trouble getting it to work.....
Unread 22-01-2012, 17:34
AKA: Brad
I shot the images with a red ring light. Did you get it to work with the image downloaded into the cRIO and not using the camera?
Also, what problem are you having?
Brad
Brad Miller
Unread 22-01-2012, 18:13
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
In regards to the earlier Eclipse question, the plug-ins will soon be updated to include this sample
CRUD Name: Windows
Alumni to Team: 350
Unread 23-01-2012, 08:56
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Would anyone be able to suggest a light ring to use? This could be extremely useful but my team does not currently have a light ring.
Unread 23-01-2012, 10:56
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
We got ours from AndyMark for 8 credits each.
Unread 23-01-2012, 15:56
docdavies's Avatar
docdavies docdavies is offline
Doc Davies
FRC #0346 (RoboHawks)
docdavies is an unknown quantity at this point
I don't seem to be able to download the "Detecting Vision Targets in C++ and Java" PDF from FirstForge.
Reasons?
Doc
Unread 23-01-2012, 16:28
AKA: Brad
You can also get them here: http://www.superbrightleds.com/cgi-b...ni_tubes. htm
Use the angel eye lights. For extra brightness you can get two sizes and nest them.
Brad
Brad Miller
Unread 23-01-2012, 16:29
AKA: Brad
Reasons?
Doc
Did you look here: http://firstforge.wpi.edu/sf/go/doc1304?nav=1
Brad
Brad Miller
