Go to Post It is easy to be righteous on Chief Delphi, and harder to implement in life. - DonRotolo [more]
Unread 23-01-2012, 11:34
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
Modified skyway wheel hub
[IMG]C:\Users\AP\Downloads[/IMG]
Unread 23-01-2012, 12:23
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Modified skyway wheel hub
What wheels are these for?
We ordered a set of skyway 10inch tires and are need to make a custom home as well..
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 23-01-2012, 12:34
Joe Finkel Joe Finkel is offline
FRC #0369 (High Voltage)
Joe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura about
These are for skyway beadlock wheel with .75inch bore
Unread 23-01-2012, 12:52
Mk.32's Avatar
AKA: Mark
How do these mount to the wheels? Do they press fit in?
Unread 23-01-2012, 13:25
The bead-lok system is a two halves plastic rim: remove 1/4inch bolts, separate the rim, take out the hub, which comes factory bored out to .75in. and the rest is machine shop work.
