Go to Post You can usually pick out the kids who will grow up to be engineers. They're the ones tearing apart their nintendo, their vcr, their minibike, and their parents' cars. - Tom Line [more]
  #76   Spotlight this post!
Unread 23-01-2012, 14:47
SkyWarrior's Avatar
SkyWarrior SkyWarrior is offline
Crazy Mentor of 2948
AKA: Mr. Celik
FRC #2948 (Prototype)
SkyWarrior is an unknown quantity at this point
Re: Bumper question
I thought the bumper should be strictly 8 inches between 2 inches from the ground and 10 inches from the ground?
Last year the rule was 1 inches to 7 inches from the ground total bumper height must be 6 inches if i am not mistaken? At least our bumpers were exactly 6 inches high.
If my bumpers are 5 inches high from the ground and still within the bumper zone, would that be legal?
Ask me about Molecular Biology, i will tell you everything.
Ask me about robotics, i will tell you go to Chief Delphi.
  #77   Spotlight this post!
Re: Bumper question
The team update does not make the frame design illegal it simply calls any bumper like assembly that is mounted inside the frame perimeter "not a bumper". The bumper is the subject of the update.
Al, that "not a bumper" makes the frame design illegal due to the bumper mounting rules. Here is my logic sequence. I will use "Bumpers" to designate manual-spec bumpers and "bumpers" to designate non-manual-spec bumpers
  1. Both sides of a vertex of the Frame Perimeter must have 8" of Bumpers. [R27]
  2. Bumpers must be firmly attached to the Frame Perimeter. [R28-E]
  3. The Frame Perimeter definition ([R01] blue box) for the robot in question is a rectangle.
  4. Because the bumpers inside the Frame Perimeter are not Bumpers ([R27], Figure 4-3), they are not adequately protecting the Frame Perimeter vertices in question per [R27]. (I know that's kind of a weird thing to say--something that is adequately protected is not considered adequately protected. But, that's the way the rules are written.) This results in a violation of [R27].
  5. There is no way to attach 8" of Bumper on the Frame Perimeter and have it be supported as required by [R33] with the design in question.
  6. Therefore, because a) [R27] is violated and b) there is no way to turn them into Bumpers without modifying the frame in question to support bumpers as required by [R33] and [R28-E], the robot frame design is illegal.
The Update didn't make the frame design illegal, true. It clarified that it was definitely illegal by declaring, once and for all of 2012, that bumpers inside the Frame Perimeter were not, in fact, Bumpers. The bumper rules take care of the rest.
  #78   Spotlight this post!
Unread 23-01-2012, 14:53
Re: Bumper question
The bumper may be mounted between 2 inches and 10 inches from the ground. However, bumper height is 5 inches (2 stacked 2.5" pool noodles, and a 5" high plywood backing). This gives 3 inches of height in the bumper zone that is not covered by bumpers.
So, if the bottom of your bumpers was mounted 5" off the ground, provided that you built to the rules, then you would most likely be legal. (Subject to inspection, of course.) If the centerline of your bumpers was 5" off the ground, then you'd again probably be legal subject to inspection (5/2=2.5"; 5-2.5"=2.5" at the bottom of the bumpers).
As far as going from one side of the field to the other without hitting bumpers, there are the bridges. You just have to get them tipped to your side.
  #79   Spotlight this post!
Unread 23-01-2012, 15:01
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Bumper question
I think you're confusing their height and width measurements. This year as with last year and previous years, bumpers must be backed by exactly 5" tall plywood (R07F 2011, R4.1.6A 2012). This year, the minimum length of bumper coverage on each side of each exterior vertex is 8" (R4.1.6). Last year, the minimum length of each bumper segment was 6" (R07D, note that the rules are actually very different between the 2 years).
  #80   Spotlight this post!
Unread 23-01-2012, 15:50
Re: Bumper question
Guys,
If you run the numbers on the diagonal of a 5" high vertical pool noodle you will find it to be 6"+. If you tilt the robot in crossing the barrier, the bumper diagonal will place the front edge of the bumper above 10" regardless of where the bumper is mounted. Please note that the GDC responded Friday with a Team Update that speaks directly to this condition.
"The carpet, the Bridge surfaces, and Keys are considered the flat floors – and thus are the reference planes for the Bumper Zone requirements. A Robot in a transitory state of crossing onto/off of a Bridge or Barrier is not considered to be on a flat floor."
  #81   Spotlight this post!
Unread 23-01-2012, 19:59
militaryrobot's Avatar
militaryrobot militaryrobot is offline
FRC #0647
militaryrobot is an unknown quantity at this point
Re: Bumper question
Originally Posted by KevinGoneNuts View Post
While I have you all here. I also have a bumper question. Attached is a picture of a bumper idea, after reading the rules it seems that this is alright? I want to be 100% sure. Does it seem okay to you?
Attachment 11290
Look legal. Our team is all ways trying to stay in legal and that is our basic bumper desgin
Our robot is less then two feet
  #82   Spotlight this post!
Unread 24-01-2012, 21:50
usacat6 usacat6 is offline
AKA: Will
FRC #2228 (Cougar Tech)
usacat6 is an unknown quantity at this point
Re: Bumper question
Still need clarification about gaps along a frame edge. Assuming Figure 4-1 in the bumper-rule section, and assuming that the displayed bumper segments are such that the portion covering a given edge is 8" (measured from corner to middle of frame), then is there a maximum length of the remaiming exposed frame, or does the amount of exposure not matter?
  #83   Spotlight this post!
Unread 24-01-2012, 21:56
Re: Bumper question
As long as you have the 8" bumper segments from the corners, there is no maximum length of exposed frame. There is also no minimum length of exposed frame.
  #84   Spotlight this post!
Unread 25-01-2012, 07:04
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper question
Well there is a maximum length, since your frame can only be 38" in total. 38 - (2*8) = 22 inches. However, if your frame is smaller, then the maximum exposed part is smaller.
The 8" bumper on corner rule doesn't say anything about what can be in between those corners. It could be an opening (to suck up balls, perhaps?) or it could be an exposed piece of frame. It's whatever your team wants to do within the flexibility of the rules.
(since 2004)
  #85   Spotlight this post!
Unread 25-01-2012, 07:30
Re: Bumper question
Will,
Please keep in mind that this part of the bumper rule does change from year to year. More often than not, the bumpers were required all the way around the frame perimeter.
  #86   Spotlight this post!
Unread 25-01-2012, 12:31
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Question Re: Bumper question
The Team Update 2012-01-24 says
Bumper Rules
[R27]
Figure 4-3 has been updated to correct the portrayal of the Frame Perimeter. ...
But I don't see the updated figure. Did I miss something obvious (I've done that once or twice before 8-) ), or did they forget to include the new figure? Can anyone tell me where to find it?
Thanks!
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
  #87   Spotlight this post!
Unread 25-01-2012, 12:34
Siri's Avatar
Dare greatly
Re: Bumper question
Thanks!
They only posted it in the manual itself, not the Team Update.
  #88   Spotlight this post!
Unread 25-01-2012, 12:44
AKA: Gerry
Re: Bumper question
Ah, I did not attempt to open the manual because the hover text still says "The Robot_Rev-". Now that I've opened it, I see it's actually at Rev B (and apparently includes updates after the 1/13/2012 date given for Rev B in section 4.2).
Thanks for the pointer, Siri.
Cal
Fairport, NY, USA
  #89   Spotlight this post!
Unread 25-01-2012, 16:10
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Re: Bumper question
There is a question on FIRST Q&A with an inadequate answer from FIRST.
Q. We are deciding to use a square U frame. So, we have to split the 4th bumper into 2 sections. Because of this, we can't decide how to place "3490" on our Bumper. Should we place the 4 numbers on 1 side, or should we split 34 and 90 across the Bumper. R35 doesn't explain how to handle this situation.
A. Per [R35] team numbers must be "clearly visible from a distance of not less than 100 ft, so that judges, referees, and announcers can easily identify competing Robots." Thus they may not be obscured in any way (disconnected, out of order, rotated, upside-down, mirror imaged, etc).
We are a 4 digit number team and we have a short front bumper on the left and one on the right (many teams do this year). I understand each short bumper must be at least 8 inches long. With the [R35] requirement
Teams shall display their team number on the Bumpers in four locations at approximately 90° intervals around the perimeter of the Robot. The numerals must be at least 4 in. high, at least ¾ in. in stroke width, and be either white in color or outlined in white. Team numbers must be clearly visible from a distance of not less than 100 ft, so that judges, referees, and announcers can easily identify competing Robots.
Each letter will be at least two inches wide. How can I fit 4 numbers in an 8 inches width? If I don't leave any space between them, it will not be very readable. Any ideas?
Please don't call me Mr. Ed, I am not a talking horse.
  #90   Spotlight this post!
Unread 25-01-2012, 16:21
Re: Bumper question
Ed,
The Q&A seems to indicate that splitting the numbers will not be allowed. I agree that the split is likely to cause some confusion. I can only guess/suggest therefore that the numbers on the short side must be less than 3/4" stroke to satisfy the Q&A response. However, if a vertical pool noodle is placed in the corner of said segment, you would have approx 10.5 inches in which to place numbers. I will ask what inspectors will be expected to check for.
