Go to Post I wonder if Dave thinks the Chief Delphi kids are pimp... - Mike Ciance [more]
Unread 21-01-2012, 22:19
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Saving Image from Axis Camera to cRIO
Guys,
I've tried using some of the imaq commands from the nivision.h library, but whenever I run the code, I don't see any images stored anywhere.
I've tried:
int imaqWritePNGFile(const Image* image, const char* fileName, unsigned int compressionSpeed, const RGBValue* colorTable);
int imaqWriteVisionFile(const Image* image, const char* fileName, const RGBValue* colorTable);
int imaqWriteBMPFile(const Image* image, const char* fileName, int compress, const RGBValue* colorTable);
And some others even.
For example: imaqWriteVisionFile(imaqImage, "filename", NULL);
I need this to see the progression during image processing.
Does anyone have any suggestions for a file path or if the fileName is expecting an extension? The code compiles and runs in most instances but just doesn't leave an image anywhere.
- Bryce
EDIT: Apparently it returns a non zero value on success and zero otherwise. I'll have to try this on Monday.
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 22-01-2012, 14:29
aya94 aya94 is offline
aya94 is an unknown quantity at this point
Re: Saving Image from Axis Camera to cRIO
Try using this command it worked for us:
AxisCamera& camera =AxisCamera :: GetInstance();
Unread 22-01-2012, 17:34
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Thanks. I'm quite a bit past that point though. I'm grabbing images, but I need a way to inspect those images between processing steps.
- Bryce
Unread 23-01-2012, 12:35
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Ok. I may have solved my own problem. If one were to take a look at the BinaryImage source code, it appears to be there.
void BinaryImage::Write(const char *fileName)
RGBValue colorTable[256];
Priv_SetWriteFileAllowed(1);
memset(colorTable, 0, sizeof(colorTable));
colorTable[0].R = 0;
colorTable[1].R = 255;
colorTable[0].G = colorTable[1].G = 0;
colorTable[0].B = colorTable[1].B = 0;
colorTable[0].alpha = colorTable[1].alpha = 0;
imaqWriteFile(m_imaqImage, fileName, colorTable);
I guess I needed to set up the colorTable properly. I haven't tried this yet, but I can't image that WPILib would have a non-working function.
- Bryce
Unread 23-01-2012, 14:00
malachias malachias is offline
FRC #1311
malachias is on a distinguished road
Your current directory is "/" in the cRIO file system so your filename is relative to the root directory for relative paths. I have only successfully written to the root directory. Not all write operations generate files. Some generate errors that are visible on the Diagnostic screen of the the Driver Station. I am not certain that the first images retrieved from the camera are usable, but then I am still fumbling around.
I open a DOS window and use FTP to retrieve files from the cRIO. I just FTP to the ip address of the robot. "ls" returns a list of files. "get [filename]" retrieves a file to you current home directory. "delete [filename]" removes files. It appears to be a standard FTP implementation so you find documentation on the web.
I put a ".jpg" extension on the file when I write it out ("snapshot.jpg"). I can specify explicitly how to format the file using a specific imaqWrite*File method, so it may not matter except to indicate to Windows the format of the file. I do not know what format file the ImageBase::Write method generates (extension may be significant here).
Unread 23-01-2012, 14:51
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Malachias,
Thanks for the response. Yeah, I figured it would probably put everything in the root directory. It's good to hear some clarification.
An easier way to FTP to the robot is to type ftp://10.xx.yy.2 into an explorer window in windows (i.e., open up My Computer and enter the address in the address bar - it may have to be added).
With respect to file names, from what I can you if you use imaqWriteFile the extension is significant. It looks like the function parses the extension and then writes the type is parsed. I'll have to try the imaqWrite*File functions as well since they have a few more options.
Again, thanks for your help.
- Bryce
Unread 23-01-2012, 15:25
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
We have been using ColorImage::Write.
Something along these lines
ColorImage img;
camera.getImage(&img);
if(savingInAComplicatedWay)
  static int cImages = 0;
  char szSavePoint[200];
  sprintf(szSavePoint, "image%d.jpg",cImages++);
  img.Write(szSavePoint);
else
  img.write("img.jpg");
It ends up as a JPG in the root of the cRio. Then we just use windows explorer and go to ftp://10.te.am.2 to access the saved images and copy them to our PC for more analysis.
My standard disclaimer of "This code is from memory and probably won't compile" applies.
