Go to Post When it all comes down to it, it's not gonna be the medal around your neck that makes the difference, but the memories that you think about when you look back on how you got there that makes the difference. - Beth Sweet [more]
Unread 23-01-2012, 12:09
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
pic: How will 3620 use this gear?
Unread 23-01-2012, 12:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: How will 3620 use this gear?
Neat, dual FPs! Are you going to add cooling air holes to the Front Plate?
Unread 23-01-2012, 12:48
Thanks! And yes, cooling holes will be needed. I am thinking 15/64" diameter, eight places on a 0.931 circle. Or something like that.
These motors do need air flow-through, or they'll cook.
Also, the detailed dimensions visible on the drawing may not be correct -- they are based on 0.8 module gear teeth -- actual tooth size is more likely 32 DP. Also, they are based on a 19 tooth pinion, and our -9013 motors have 13 tooth pinions.
Richard Wallace
since 2003
Unread 23-01-2012, 13:55
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
If your clearance hole for the pinion was smaller the motor will sit on the orange washer. Just need to use longer screws for the motor. Your air flow problem will be solved.
Roy
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 23-01-2012, 14:59
MrForbes's Avatar
AKA: Jim
Yes, but how do you accurately locate the motor?
Unread 23-01-2012, 15:14
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Originally Posted by Richard View Post
Let see. if that is the FP and the first stage from the FP gearbox you have a 13 tooth pinion and a 72 tooth driven gear that gives a speed reduction of 72/13 = ~5.54
Based on data from the FIRSt provided motor specs (http://www.usfirst.org/sites/default...torInfo4.1.pdf) the FP -9013 has a free speed of 16700 RPM. After this reduction that works out to ~3015 RPM. Gosh Richard, what could you ever want spinning that fast?
I wonder if you put a wheel on that shaft what kind of surface speeds you could get?
Mark
Brick walls are for other people. - Randy Pausch
Unread 23-01-2012, 16:17
My head seems to spin that fast, frequently.
Richard Wallace
since 2003
Unread 25-01-2012, 11:58
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Ba dum tsshh!! (you know, with drum and symbol)
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
