Thread Tools |
Rating:
Display Modes |
#12
Re: 2012: Tuning the Jaguar's Speed Control PID Loop
So I finally had a chance to play with PID control on the Jag over can... below is my initial assessment... note these are just my opinions so don't let it sway you in making your decision when choosing the Jags over the CRIO.
First off, I was controlling a CIM motor, directly coupled to a shaft... spinning a 6in wheel. I was using BDC-com directly connect to the Jag (so it was a black jag) over a USB to serial interface, and there was only one Jag on the network. My encoder was a 256 pulse per rotation grayhill encounter (or as TI likes to call it a 256 line encoder) tied directly to the shaft using shrink tubing. Summary: I was able to effectively get pretty accurate speed control using a PI controller, and good postiton control just using a P controller. However, the problems that I noticed are with paramters that I can not control due to the nature of the Jag being a black box PID controller to me. I talk about these nuances below, and because of them I don't think I am comfortable enough to use the jags for my PID loops this year, even though I will still be running CAN-Bus for all of my motors. First impressions: Encoder sampling time - The sampling time of the encoder seemed to be very slow. It was "good enough" for most of what I wanted to do but slow for really high speed rotations. To stablaize around 2500 RPM, I was noticing +/- 200 rpm jumps from the speed readout.The feedback from the sensor is an integral part of how reliable the controller will be... and there was no way to average the output of the encoder to smooth it out on the Jags (as I would do on the C-RIO using an N-point average). But the biggest problem was, I don't know what the sampling time of the encoders are - looking at the data sheet, section 8 does not mention sampling rate as it does for other inputs, The rate that it does talk about seems to be encoder velocity specified in Mach (unit M). So not knowing how fast the encoder is sampling is a pretty big deal to me. I would expect the sampling time to be in the kHz range, in which case it is fast enough I wouldn't care. Now the fluctuations I was getting from speed could have easily been due to a torsional spring effect due to the loose coupling of the encoder to the shaft, but I can't be certain without further testing. No Integral wind-up prevention - (Or at least im not sure if the controller contains this feature) - When I look at the code posted... PID.c seems to have integral level min and max values to prevent integral windup. However, we can't be sure that the code were looking at is the code that is runing on the FIRST version of the JAG can we? I don't see why there would be two different versions of the firmware on TI's end, but using BDC com I did not see a way to provide limits on the integral. So windup is an issue, and although I didn't notice any wind-up in my tests, I didn't run the test long enough to make sure there was no windup. Windup can take seconds or even minutes to see the effect. One encoder/One Motor - This is an obvious one, but because the encoder is tied to only one motor, it is difficult to control two motors using one encoder. I am sure there are solutions available, but at a risk I am not willing to take unless my back is against the wall and the loops are maxing out the cRIO (which I don't think will be the case). However, if you can over look these problems, I was able to get a decent controller in about 10 mins on the Jag and would recommend the Jag for certain non-critical tasks. My gains were P=0.08, I=0.004 for speed control and P=0.3 for position control. I used Matlab/Simulink to determine the gains of the controller. Thanks, Kevin |
