Go to Post theyre not planning on blowing up the comet... just running straight into it and seeing what happens. :D - Winged Wonder [more]
Unread 23-01-2012, 14:59
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Solidworks help??
So after speaking to our sponsored machine shop, which is AMAZING by the way and a complete life saver, my student edition of solidworks cannot export in different file types, cannot be saved as .sldwrk file and opened in mastercam, cannot transfewr CAD file to professional version to be viewed or exported from there. So there is no way to get my complete robot parts needed for FIRST over to the machine shop. WE NEED HELP! We don't have the funds, and our robot wouldn't function without any of these parts! What are we to do???
Unread 23-01-2012, 15:28
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
Re: Solidworks help??
we have had the same problem its almost simpler to make print on your part and redraw it on mastercam real quick
Unread 23-01-2012, 15:50
Brandon Holley's Avatar
Can you still save to a STEP file from the student version? If so, can MasterCAM open that?
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 23-01-2012, 15:59
jgbruno jgbruno is offline
FRC #0359
jgbruno is an unknown quantity at this point
If the machine shop is using Mastercam then you can turn the solidworks file into a STEP file.
FRC #4084
The student edition doesn't allow exporting to anything other than another student version. Even professional can't have the files transfer. It really sucks. I found a converter from http://www.rhino3d.com/ that allows .stl files to be imported then saved as .step files (which is what mastercam works best with). It only allows for 25 saves so use them wisely!
We also do not own mastercam, and can't make our parts that easily and quickly since the machine shop uses their mastercam versions and the parts are rather complicated.
We're waiting to here back tomorrow if our machine shop, Hartwick Machining which is a LIFE SAVER for our team in North Texas to see if the part will work on mastercam. The student edition tries to import but just gives errors.
Edit* Hartwick Machining - http://www.hartwickmachineshop.com/home.nxg
We do really love the help they provide!
Unread 23-01-2012, 16:08
FRC #0359
In the solidworks student version you can change the sldprt. into a STEP file (stp) where the machine shop can upload to their mastercam. Are you getting these parts CNC?
Unread 23-01-2012, 16:19
FRC #4084
Student edition does not let you export in anybother file type than .Sldprt. BUT if you put it into edrawings you can save as .slt. The slt cannot be used by anything else because it has errors when forming the solid. But using rhinoceros it can then be put into .step
Unread 23-01-2012, 16:21
When you say "export" are you referring to the operation File->Save As?
I don't have the student edition on this computer so I cannot verify, but I'm dumbfounded that you'd be unable to do a File->Save As and not save to an IGES or STEP format.
-Brando
Unread 23-01-2012, 16:36
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Which version are you using?
The student edition definitely allows you to save in step format. I have done it several times in 2009 and 2010.
To do this, open your part, click "save as," find on the dropdown menu where is says STEP (.stp) and click that. Name your part to the desired name and you should be done.
Unread 23-01-2012, 17:13
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
I had an educational copy of Solidworks a while back that would not let me save as anything other than Solidworks files. My license was 150 day educational license for "Solidworks Standard". Inventor can open Solidworks files however, so if you can't figure anything else out just open the parts in Inventor and then save them as a step file.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 23-01-2012, 18:45
FRC #4084
Exactly. You cannot I mean CANNOT save as anything other than sldprt in solidworks standard edition educators license 2011. period. I'm looking at it now. Inventor I guess can but I found a simpler way if I just need to send to to someone instead of download another file
Unread 23-01-2012, 18:48
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Which student version? I use the one my college gives us for free and our machine shop has no issues.
Unread 23-01-2012, 18:53
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: Solidworks help??
Mastercam has a free addin that allows direct export into mastercam, not sure if this works with the student version though.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 23-01-2012, 18:59
Garret's Avatar
AKA: Garret Smalley
From my understanding the version he is talking about it not the student version. The Student Version is "Solidworks Premium" whereas the Educational licenses that he is referring to is "Solidworks Standard".
7 Years of FRC
Unread 23-01-2012, 19:47
FRC #4084
Well it also depends on what software the cnc machine uses. Some machine shops use student edition as well to open parts then uses a converter.
