Solidworks help??
So after speaking to our sponsored machine shop, which is AMAZING by the way and a complete life saver, my student edition of solidworks cannot export in different file types, cannot be saved as .sldwrk file and opened in mastercam, cannot transfewr CAD file to professional version to be viewed or exported from there. So there is no way to get my complete robot parts needed for FIRST over to the machine shop. WE NEED HELP! We don't have the funds, and our robot wouldn't function without any of these parts! What are we to do???
Re: Solidworks help??
Can you still save to a STEP file from the student version? If so, can MasterCAM open that?
If the machine shop is using Mastercam then you can turn the solidworks file into a STEP file.
We also do not own mastercam, and can't make our parts that easily and quickly since the machine shop uses their mastercam versions and the parts are rather complicated. We're waiting to here back tomorrow if our machine shop, Hartwick Machining which is a LIFE SAVER for our team in North Texas to see if the part will work on mastercam. The student edition tries to import but just gives errors.Edit* Hartwick Machining - http://www.hartwickmachineshop.com/home.nxg We do really love the help they provide! |
In the solidworks student version you can change the sldprt. into a STEP file (stp) where the machine shop can upload to their mastercam. Are you getting these parts CNC? |
#7
Student edition does not let you export in anybother file type than .Sldprt. BUT if you put it into edrawings you can save as .slt. The slt cannot be used by anything else because it has errors when forming the solid. But using rhinoceros it can then be put into .step
#8
I don't have the student edition on this computer so I cannot verify, but I'm dumbfounded that you'd be unable to do a File->Save As and not save to an IGES or STEP format. -Brando |
#9
The student edition definitely allows you to save in step format. I have done it several times in 2009 and 2010. To do this, open your part, click "save as," find on the dropdown menu where is says STEP (.stp) and click that. Name your part to the desired name and you should be done. |
#10
I had an educational copy of Solidworks a while back that would not let me save as anything other than Solidworks files. My license was 150 day educational license for "Solidworks Standard". Inventor can open Solidworks files however, so if you can't figure anything else out just open the parts in Inventor and then save them as a step file.
#11
Which student version? I use the one my college gives us for free and our machine shop has no issues.
#13
Mastercam has a free addin that allows direct export into mastercam, not sure if this works with the student version though.
#14
From my understanding the version he is talking about it not the student version. The Student Version is "Solidworks Premium" whereas the Educational licenses that he is referring to is "Solidworks Standard".
#15
Well it also depends on what software the cnc machine uses. Some machine shops use student edition as well to open parts then uses a converter.
