Go to Post teams that REALLY deserve to win will find ways to overcome a marginal officiating decision. Also, teams that REALLY deserved to win will try not to put themselves in that position. - Chris Hibner [more]
Unread 23-01-2012, 15:49
JesseGR JesseGR is offline
FRC #3539
JesseGR is an unknown quantity at this point
Trajectory Calculator (W/ Drag)
Hello, my name is Jesse and I am a programmer from team 3539. In a few hours of downtime I had between our current projects, I applied a few physics formulas to a Java application and made a calculator that can accurately determine the path of an object when fired at an angle and a velocity, among other things.
http://img841.imageshack.us/img841/9954/77059684.png (Screenshot)
http://www.box.com/s/svmj0ln7vvzdh27pqckv (Download)
The ideal "Calculations per Second" setting is 5000, make sure you change it from the default of 5.
Enjoy.
Unread 23-01-2012, 18:02
Re: Trajectory Calculator (W/ Drag)
How do you know it is accurate? i.e. what test data did you use to validate your model?
Unread 23-01-2012, 18:07
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
I can't seem to run this on my computer. Cannot find main class...?
Either way those curves don't look like there is any drag. Did you physically measure the air drag coefficient?
Unread 23-01-2012, 18:12
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
Check it against mine?
I also wrote something about 2 weeks back. This one is in GNU Octave/Matlab
https://github.com/FRCTeam4069/Simul...sketball_sim.m
Unread 23-01-2012, 22:18
Lalaland1125 Lalaland1125 is offline
AKA: Ethan Steinberg
FRC #2429
Lalaland1125 is an unknown quantity at this point
Our team started working on the same idea(manually integrate the drag + projectile formulas to calculate the projectile path)(http://ideone.com/aoChY, but we haven't quite gotten it to the level of completeness you did.
This is going to require a lot of testing to get the constants right though(and to see if it is accurate at all).
(Also, no offense, but I would heavily suggest for you to refactor your code. All of those functions with repeated code and the whole "god" class is going to make things hard to modify and debug later on)
Unread 23-01-2012, 23:41
robokiller robokiller is offline
AKA: Jaxon Weis
FRC #2757 (B.A.D.)
robokiller is an unknown quantity at this point
I really want to play with a couple of these programs but yours is not working on my computer
"could not find main class: Main program will exit"
-- Jaxon Weis
Unread 25-01-2012, 22:38
Originally Posted by shuhao View Post
Check it against mine? I also wrote something about 2 weeks back.
Unread 25-01-2012, 22:58
Comparing a model to a model doesn't prove that either is correct. It only proves that they included similar factors, not that they included the correct factors (and factored them in correctly). The only way to validate a model is to compare it to actual test data.
Unread 26-01-2012, 00:01
I was making a joke .... cmon..
Unread 26-01-2012, 00:42
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Due to the relative light weight to the size of the ball this year, trajectory calculation this year cannot ignore air resistance and it also cannot ignore back spin for those who are using a single wheel. Back spin make the ball travel higher and further.
If you ignore air resistance or back spin and try to correlate to real test data by scaling the exit velocity, it would be meaningless. Adding air rsistance to your calculation would be an improvement because you have the shape constant to tune but you are still ignoring an important factor which is the back spin. The back spin is significant especially when you are shooting from far away.
I will be posting my trajectory calculator (in Excel) on our website soon. You can look at the calculator for 2008 and 2010.
We have not done tuning yet. Our robot will not be done for another 2 weeks.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 01-02-2012, 22:49
gnunes gnunes is offline
FRC #1391 (Metal Moose)
gnunes has a spectacular aura aboutgnunes has a spectacular aura aboutgnunes has a spectacular aura about
Here is a LabView trajectory calculator including the effects of drag and spin. You can adjust how much drag and how much spin (and whether it is back spin or top spin). You can also change which hoop you are aiming for and the height of your shooter exit point.
I've not tested it against any measurements, but the physics of spinning balls has been extensively studied, so it should at least be close. The biggest approximation is for the lift coefficient, where I have used a very simple model, and assumed that the spin does not slow during the flight. If you want to see what a complicated model for lift looks like, read the AJP paper referenced on the block diagram, where he develops an empirical model for spinning tennis balls...
Unread 14-02-2012, 19:30
Bendito's Avatar
Bendito Bendito is offline
AKA: Benjamin LaRoche
FTC #7837 (The Thunder Colts)
Bendito is an unknown quantity at this point
Now, the real question is, how do we have this trajectory calculator solve for angle if the velocity is constant?
Unread 15-02-2012, 09:23
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
That part is really tricky. What I did in my calc (which does not do drag!) was to have it iterate the angle until the calculated path went through the target basket. I did this using Excel's goalseek function. Then you make a table of different ranges to shoot from, and graph it. Add a trendline to generate an approximate formula for that velocity (I used Order 3 polynomial to get a high R^2 value). That simplified formula is what you would integrate with your robot code if you wanted to automate the angle.
Unread 15-02-2012, 09:42
It's not tricky if you're ignoring drag and magnus effect (backspin)1. There's an explicit closed-form solution. See the last two equations on page 2 of the attachment.
1 of course, ignoring drag and backspin is probably not a valid assumption for this case. see post#10.
Unread 15-02-2012, 12:05
Bendito's Avatar
Yes, I already have vision tracking getting a distance, using trigonometry to find the base of the triangle (distance of launcher parallel to the floor to the hoops) from the hypotenuse (distance of vision target from camera) and the opposite side (the known height of the hoop) and running it through an equation found on wikipedia to find angles to hit a target point (x,y). It has not been tested on the robot, but the math and plotted trajectories it outputs look sound.
I am trying to incorporate drag into this, however, it seems incredibly complicated, based on the vi's mentioned earlier. Compensating for air resistance within a set range might practically be accomplished through adding an arbitrary number to the x and y in that equation based on trial and error. There are some good drag equations on this page, too, though.
http://en.wikipedia.org/wiki/Trajectory_of_a_projectile
Edit: Use regressions and plot out the real world values to find an equation? IE. A function of angle on the Y axis and how far it travels until contacting ground (possibly set at a particular height, such as the top hoop) on the X (or vice versa)
