Go to Post I, as a programmer, always strive to have the entire robot operate with as little driver input as possible. Those pesky humans.... - dellagd [more]
Unread 23-01-2012, 16:52
rai337 rai337 is offline
FRC #1574 (Miscar1574)
rai337 is an unknown quantity at this point
accelerometer adxl345 isnt working
we tryed to make it work for 5 days, with no success, all the connections are fine, and we use then new code example but when we run it, it said 0 only.
we checked and it stuck in an endless while loop in:
adxl345 SPI open -> SPI read -> a while loop that stop when:
"SPI read #convd(i think)" isnt equal to 0 - and it send 0 only..
if anyone know what exectly is the problem, please help us.
Unread 23-01-2012, 18:53
adf0221 adf0221 is offline
FRC #1517 (Lumberjacks)
adf0221 is an unknown quantity at this point
Re: accelerometer adxl345 isnt working
Which cord are you using to connect your c-rio to your digital sidecar? We had this same issue and fixed it by connecting the new ribbon cable instead of the cable from past years.
Hope this helps!
Unread 24-01-2012, 06:49
we tryed the both of them, and none of them work..
Unread 24-01-2012, 13:22
petet4 petet4 is offline
AKA: Pete Thomas
FRC #0706 (Cyberhawks)
petet4 is on a distinguished road
Try using the address 0XA6, the sensor documatation indcates that the default address is 0x3A and 0xA6 when shorting J1. I belive the documentation is in error.
Once the address was changed to 0xA6 I2C communications worked. Also confirmed this by ohming the alt addrss per the Analog devices data sheet.
-pete
Unread 25-01-2012, 08:23
the address change will work for I2C only or to SPI too?
