Go to Post a robot is never finished... It can always be redone and improved. - EricVicenti [more]
Unread 23-01-2012, 18:59
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Problem with Vision Processing VI
I have been having problems with the 2011 Labview Vision Assistant. Every time I use it to create a VI and run it, it says
NI_Vision_Development_Module.lvlib:IMAQ Set Calibration Info loaded with errors on the target and was closed.rrect function name.
I've been struggling with this problem for days, but have yet to come up with a solution. Any ideas?
I've attached the VI and snippet for both the vision processing and the code created by the vision assistant.
Name:	Vision Processing Snippet.png
ID:	11532  Click image for larger version
Name:	Vision Assistant Snippet.png
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 23-01-2012, 22:47
Re: Problem with Vision Processing VI
My approach would be to probe the code that computes the file path to the Calibration Data. I suspect that the file is not on the controller (it may need to be ftp-ed to the cRIO), or it is not loading.
I'm also a bit concerned that the image code is pretty heavy weight. I'm curious to hear how long it takes.
Greg McKaskle
