Go to Post If something on your robot isn't working, then why don't you take the responsibility to fix it? Isn't that what being a TEAM is all about? - dlavery [more]
Unread 23-01-2012, 19:15
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Ultrasonic sensor help needed
Hey guys
Been playing around with the ultrasonic sensor for a few days now. We have it set up plugged into the analog port 1. I initially used the labview example to test it, but the number given never changed. Today, I worked with new code that I found online. Attached is this code. It correctly gets the voltage like it is programmed and displays it to the dashboard, but in lays a tougher problem. Once again the number never changes. The voltage shown sticks at something like 4.56 for the sensor and never changes if I move it around.
Any ideas?
Name:	Ultrasonic code picture.jpg
