Re: Amount of Ball Squeeze
It depends on the ball type. This year I'm thinking approx. 1.75"-2.25"
We found that about 2" works well, but it depends on what you're trying to make the ball do and how you're doing it.
From what I have seen, the average is about 2inches.
But the range is about .75 to 3-4 inches. Prototyping will be the best way for you guys to figure out what works best for you. Last edited by Mk.32 : 23-01-2012 at 19:44. Reason: Clarity |
Uhh isn't .75 the same as 3/4?
#7
The original post was edited to replace the / with -
#8
Depends on the range you want to shoot. We've found that 1.5" is pretty good.
#9
Depends on your shooter wheel tread.
In all of our prototypes, we've never had > 1". We've also never used skyway wheels. |
#10
working with our prototype last weekend, I found the smallest change in pressure at the right point really affected the behavior of the ball. Pushing on the lexan hood with my thumb at about 45 degrees angle was enough to go from the 2pt hoop to the 3pt hoop.
How long the ball stays compressed and in contact with the wheel and the contact with the hood as it is leaving the shooter also affects the angle of the shot. Prototyping the shooter was certainly worth the effort we put into it. |
#11
The main factors we have found that affect shooter variables:
When in doubt, do one last prototype... |
#12
Do a prototype. I'm on two teams right now (2079 and 619) and they both came to drastically different conclusions about the amount of squeeze, but both teams have functioning systems.
