Go to Post Don'tcha love technology? :p - Cory [more]
Unread 23-01-2012, 18:36
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Amount of Ball Squeeze
What is the consensus regarding the amount of "squeeze" on the ball as it leaves a shooter (1 or 2 wheel configurations)?
Unread 23-01-2012, 19:18
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Amount of Ball Squeeze
It depends on the ball type. This year I'm thinking approx. 1.75"-2.25"
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 23-01-2012, 19:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We found that about 2" works well, but it depends on what you're trying to make the ball do and how you're doing it.
Unread 23-01-2012, 19:26
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
From what I have seen, the average is about 2inches.
But the range is about .75 to 3-4 inches.
Prototyping will be the best way for you guys to figure out what works best for you.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 23-01-2012, 19:40
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
But the range is about .75 to 3/4 inches.
Uhh isn't .75 the same as 3/4?
Unread 23-01-2012, 19:44
Mk.32's Avatar
AKA: Mark
I meant 3 to 4 inches. ^_^
Unread 23-01-2012, 21:14
Chris is me's Avatar
AKA: Pinecone
This is a LARGE range of performance! People skimming CD to get a number for their CAD model or block of wood prototype should take a look at these numbers and realize that they need to make an adjustable rig, or multiple setups of the shooter in order to make the robot work.
The main factors we have found that affect shooter variables:
  • Surface ball is compressing against. This could be a wheel, a pair of wheels, or multiple wheels / roller. Some teams experiment with making their wheel concave.
  • Tread material. Different materials deform in different ways, and ultimately a shooter that works using compression will have different dynamics with different materials on each side of the ball. We like our smooth sheet steel hood, and aluminium works just as well for our setup.
  • Method of loading. Many teams are loading their shooters from underneath, modeling their robots off of the popular ground loaded turreted shooters from Lunacy and Aim High. Others may be building mechanisms that load with gravity. Results WILL vary!
When in doubt, do one last prototype...
Unread 23-01-2012, 22:29
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Do a prototype. I'm on two teams right now (2079 and 619) and they both came to drastically different conclusions about the amount of squeeze, but both teams have functioning systems.
Unread 24-01-2012, 00:02
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Unread 24-01-2012, 00:31
MrForbes's Avatar
AKA: Jim
The original post was edited to replace the / with -
Unread 24-01-2012, 08:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Depends on the range you want to shoot. We've found that 1.5" is pretty good.
Unread 24-01-2012, 08:12
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Depends on your shooter wheel tread.
In all of our prototypes, we've never had > 1". We've also never used skyway wheels.
GitHub
Unread 24-01-2012, 08:43
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
working with our prototype last weekend, I found the smallest change in pressure at the right point really affected the behavior of the ball. Pushing on the lexan hood with my thumb at about 45 degrees angle was enough to go from the 2pt hoop to the 3pt hoop.
How long the ball stays compressed and in contact with the wheel and the contact with the hood as it is leaving the shooter also affects the angle of the shot.
Prototyping the shooter was certainly worth the effort we put into it.
The views expressed are mine and should not be construed to represent the views of anyone else.
