Go to Post Truly good teasers should give people a good place to start guessing, while still leaving some mystery and uncertainty. - Travis Covington [more]
Unread 23-01-2012, 20:28
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Potentiometer and LabView
Hello -
I'm trying to get our potentiometer to work. This potentiometer did not come in any FRC kit of parts, it's just one we had laying around.
We've got it going into Analog Input 2. When in the drivers station, we see the voltage change on Analog Input 2 as we turn the shaft of the potentiometer.
Now, I've been trying to get the $@#$@#$@#$@# thing to display the angle, but it just won't work with me. Here's where I open it in begin.vi.
For some reason, it won't take the analog channel.
Now, here's what I have for teleop.
This just takes the voltage and turns it into an angle based on the conversion factor of 0.01388 volts per degree. It then flattens it and sends it off to the drivers station where it's unflattened and thrown into a numeric display.
Any help? Thanks.
Unread 23-01-2012, 22:03
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Potentiometer and LabView
Delete your current control and then create a new one by right clicking on the Analog Channel node on the Open VI and selecting Create->Constant.
Unread 23-01-2012, 22:15
FRC #0023 (PNTA)
Rookie Year: 1620
Seems to have worked, thanks! I'll test it tomorrow and let you know how it goes.
