Go to Post FIRST rocks, thats for sure. - Dan Richardson [more]
Thread Tools Rating: Thread Rating: 11 votes, 4.64 average. Display Modes
Unread 23-01-2012, 18:14
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Polycord welding
I've searched CD for poly cord welding info and I think I have the general technique down but they are based mostly on textual descriptions. Here is the technique I'm hearing.
1) Take care, use gloves, and don't get melted urethane on your skin.
2) Cut poly cord to length of about 3-5% shorter than length of run, even though mfgr says 10%.-- 10% is overkill and puts more tension on things than you want and just makes things more of a pain.
3) Joint cuts can be square cut or angle cut (not sure if it matters)
4) Heat/melt both ends by pressing against piece of aluminum, and heating opposite side of aluminum with torch. Or use heat gun, but that would seem to be more messy.
5) using angle alum as a guide to align, press ends together firmly for several minutes, then let set for several hours before using. Seems like a small u-channel or tubing that matches diameter may be even better for aligning.
A couple of questions:
Some writings seem to imply that the tubing should be stretched while welding. Not sure what is meant by this-- the only thing I can think of is that you put it around your pulleys and weld it into its final installation, stretching to make the ends meet-- makes sense if you can't install it otherwise after it is a loop, I guess, but in our case, we can weld separate from the bot and then install with little difficulty (I hope, or am I missing something?)
One poster suggested using a block (of alumninum?) and drilling a hole to match cord diam. and then splitting the block to aid in alignment.
It would be great if someone who has proven success with welding solid core could post a easy to follow video on how to do it (without buying a welding tool for several hundred dollars!)
Thanks.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 23-01-2012, 18:25
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Polycord welding
Try a laboratory hot plate for the heat source (use an aluminum plate to protect its surface).
Aluminum structural extrusions (e.g. Bosch Rexroth) provide channels of approximately the right size for alignment.
I've never tried to weld it in place. The robot was designed so that the belts could be installed later. We just guessed long with the length, and would have re-welded it if it was too loose.
Unread 23-01-2012, 18:35
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: Polycord welding
http://www.fennerdrives.com/eagle_po...ding_kits.aspx
You could also use a hot razor blade, place the two ends oposite each other on the blade, apply inward pressure until the two ends are melted and remove the blade, keeping the 2 ends pressed together for 5min, or whatever your belting requires.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 23-01-2012, 20:10
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We made a welder that works very well. Basically it's a piece of 8020 extrusion, 2 short pieces of angle, and two binder clips. Rubber band puts pressure on the two ends, they are aligned and slide on the 8020, and a soldering gun with a small aluminum plate bolted to the tip for heat.
I posted a pic to the CD-media, will link to it when accepted.
Unread 23-01-2012, 20:32
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Generally angled cuts are stronger because there is more surface area for the joint but they are a bit more difficult to make because they are harder to line up and harder to keep the edge from melting away. With angled cuts, you also have to make sure that both ends are cut at the same angle and so that the cord doesn't have to be twisted to complete the band.
Jason
Unread 23-01-2012, 21:27
DonRotolo's Avatar
Back to humble
FRC #0832
4: Use a thin flat plate or blade that is hot (like a soldering iron tip) to put between the cut ends, then just pull it away when you have good melting. Heat gun won't work.
5. Once it reaches room temperature it is as strong as it will ever be. Don't need to wait hours. After pressing together, cool it with a little water, no need to wait minutes.
Unread 24-01-2012, 01:11
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
What we do is take a drill bit a bit larger than the thickness of the polycord and drill into a piece of solid aluminum with it and then cut that piece in half at the point of the hole. We then cut the polycord to length, melt the ends, place it between the 2 pieces of aluminum and squeeze it into shape. We then let the polycord rest in the mold which is held together by a clamp and when it is done we cut away the excess.
We have used polycord of all sorts in our last 3 robots so feel free to pm me with any of your questions. I would recommend using the round 2 inch pulley polycord, we have never had any problems with it and I have even seen a team use it on their drivetrain(I do not recommend this).
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 24-01-2012, 01:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I've had good luck with a "Hot Knife For Her" from Michael's arts and crafts store. We custom made a bigger blade for it and made a jig to hold the belt ends and keep them aligned. No need for an angled weld. If done properly, you'll never break it with a normal butt weld.
Unread 24-01-2012, 07:39
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
We've been doing polycord for eons. We have NEVER used an alignment device - just stuck the ends together by hand. We've never had a problem.
It really doesn't need to be complicated. Polycord is VERY forgiving. Just be sure not burn yourself.
Unread 24-01-2012, 08:27
Spen.M.P.'s Avatar
Spen.M.P. Spen.M.P. is offline
FRC #3815 (Raider Robotics)
Spen.M.P. is an unknown quantity at this point
The past several years I have used both a jig and without a jig. The jig I used was a simple piece of wood with two clamping latches on it that held the to ends tight. Then I melted the ends with a lighter or soldering iron and pushed them together. After that year, I have just held them together with two pairs of pliers then heated up the ends and pushed together. Note: second method requires two people.
Unread 24-01-2012, 09:19
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Is welding better than using the inserts?
Our team chose to use the inserts because it would be faster to fasten them together and my teacher thinks that welding it is crazy. And it seems easy to repair if broken or easy to replace if we ever need to becuase you can connect the polycord while on the robot. If i am wrong with anything please explain...
Thanks
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 24-01-2012, 09:42
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
My text-book understand of polycord is that the inserts require a large pulley radius to work properly, something on the order of 4"-5", which is annoyingly big.
Unread 24-01-2012, 09:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The McMaster Carr catalog pages for the cord show hollow cord, with the minimum pulley size, and based on that we bought the hollow 1/4" cord and the aluminum connectors to use on 2 inch OD "pulleys". So far it works fine. If we do have problems with the connectors, we could weld it together.
Unread 24-01-2012, 09:47
Thanks
We've had polycord break during a match (got snagged and broke). Fixing it with welding while on the robot is easy - 1) grab each end of the broken cord, 2) heat ends until gooey, 3) press together until hard (about a minute).
If a blob forms when pressing together, it can be easily trimmed to remove the blob with an x-acto knife.
(edit: BTW, I don't recall ever seeing polycord snap at a weld. I'm sure it has happened, but the weld seems just as strong as the rest of the cord.)
Unread 24-01-2012, 15:07
http://www.chiefdelphi.com/media/photos/37270
