Go to Post Change your process to change your product. - Justin Montois [more]
Unread 23-01-2012, 21:32
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Re: Ultrasonic sensor help needed
Originally Posted by DonRotolo View Post
Verify that there is +5 volts on the +5 pin, with the black DMM lead on the GND pin. If not, check both. Verify correct polarity at the same time.
If yes, then put something about feet from the sensor - the ceiling makes a nice target if you're working on a table. The voltage at tha AN pin, again with the black DMM lead on the GND pin, should be about 0.6 volts - more precisely, it should be 0.01 volt per inch. 60" = 0.6 V
If all that is fine, the sensor is working properly.
Thanks for the help. I'll try this tomorrow.
What should I do if the sensor still remains at the constant 4.56 volts or so?
Unread 23-01-2012, 22:01
DonRotolo's Avatar
Back to humble
FRC #0832
Get another one, 'cause that one's bit the dust.
All assumes that you know what you're saying when you wrote "so its correct". Maybe have someone look real carefully for solder bridges and other issues?
Unread 23-01-2012, 22:03
FRC #4272
I sure hope it's fine! Do you think it may be a "dead" one because of the constant voltage it shows?
Unread 23-01-2012, 22:33
DonRotolo's Avatar
Back to humble
FRC #0832
My suspicion is that you're reading the supply voltage. Particularly because the sensor has a maximum range of 255 inches (2.55 volts). But it's fed with about 5 volts...
Little solder globs can do that sort of thing. As can little 'hairs' of copper wire. and so on.
Unread 23-01-2012, 22:37
FRC #4272
Thanks. I'll check it out tomorrow
