Go to Post Programmer's pride. FIRST needs some more. - Ben Margolis [more]
Unread 23-01-2012, 22:01
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Ultrasonic sensor help needed
Originally Posted by jhellr13 View Post
Thanks for the help. I'll try this tomorrow.
What should I do if the sensor still remains at the constant 4.56 volts or so?
Get another one, 'cause that one's bit the dust.
All assumes that you know what you're saying when you wrote "so its correct". Maybe have someone look real carefully for solder bridges and other issues?
Unread 23-01-2012, 22:03
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
I sure hope it's fine! Do you think it may be a "dead" one because of the constant voltage it shows?
Unread 23-01-2012, 22:33
DonRotolo's Avatar
Back to humble
FRC #0832
My suspicion is that you're reading the supply voltage. Particularly because the sensor has a maximum range of 255 inches (2.55 volts). But it's fed with about 5 volts...
Little solder globs can do that sort of thing. As can little 'hairs' of copper wire. and so on.
Unread 23-01-2012, 22:37
FRC #4272
Thanks. I'll check it out tomorrow
