Go to Post When you come down to it, FIRST is about people inspiring other people; STEM and the robots are just the subject matter. - RyanCahoon [more]
Unread 20-01-2012, 20:34
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
Re: Camera not responding
Our camera is so far functioning through the router.
Not necessarily consistently. (I'll have to look into that) But working!
Unread 23-01-2012, 21:02
woodk woodk is offline
FRC #2809
woodk has a spectacular aura aboutwoodk has a spectacular aura aboutwoodk has a spectacular aura about
We are also seeing camera connectivity issues.
We have the camera plugged into the router/access point, the IP set correctly (10.te.am.11) and can ping it from our development laptop, but cannot see it via the Web browser or get images from it in the code (using C++.) We have had no problems in past years but nothing shows up on the dashboard, we get failure to connect error messages on the console when the robot code is running, and we cannot see the camera via http (which we were able to do a couple of days ago, so something must have changed since but I have no idea what.)
The bottom line is: the network configuration looks fine, the camera is powered and appears on the network and can be pinged, but either there is some failure in the camera initialization or some subtle issue with the network config.
Any suggestions would be much appreciated!
Unread 23-01-2012, 22:39
Turing-complete
I would try reconfiguring. Hold the button on the camera as you power it on, wait for the lights, and use the camera setup utility or BETTER YET setup the camera manually.
Usually when our camera has some fatal errors, I have to reset and reconfigure for it to get back to normal.
Unread 23-01-2012, 22:41
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Originally Posted by nickpeq View Post
...setup the camera manually.
Here is a post with some pretty detailed instructions for manual camera configuration
Unread 23-01-2012, 22:49
Turing-complete
Some questions on that:
Why is the gateway not set? What happens if I do set it? Is that why my robot seems a little...glitchy?
And why not use the crossover cable? Is it just as good either way?
