Go to Post Students design and build it, the engineers/mentors are there to guide us when we stray off the path. A great way to learn, a great way to mentor, a great way to grow. - chellyzee93 [more]
Unread 23-01-2012, 22:42
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How are you feeding balls to your shooter?
That sounds very familiar, Don. I guess you took the words out of my mouth
http://www.youtube.com/watch?v=KB9IiNlYZm8
Unread 23-01-2012, 23:04
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I hope the giant up arrow makes it onto the final product.
Unread 23-01-2012, 23:09
MrForbes's Avatar
AKA: Jim
So does Nick
Unread 23-01-2012, 23:22
Borobo Borobo is offline
AKA: Patrick
FRC #0159 (Alpine Robotics)
Team Role: CAD
Borobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really nice
we aren't really using a shooter, more of just a dunker, but we're using a combination of 2 polycord conveyor belts so that one functions as the feed (the bottom one) and the top will both store and quickly launch our 3 balls. Instead of putting one belt on either side of the ball, we will just have one motorized side which pushes the balls against the other, which will have a grippy surface to just roll them up the wall, which, we hope, will save on motors, power consumption, and weight.
Unread 24-01-2012, 01:03
legogeek24's Avatar
legogeek24 legogeek24 is offline
AKA: Dirk
FRC #3562 (LiveWire)
legogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura about
We're using a swiveling "cannon." It will rotate to the ground to suck balls in, store them, then swivel up to shoot them at the hoops. A very unique design I've never seen implemented in my limited experience.
4 year FIRST alumnus and current MIT Computer Science student
Mentor for LiveWire 3562 and The Arabian Knights 4928
"1...2...3562!!!"
Unread 25-01-2012, 13:09
LDunnigan LDunnigan is offline
FRC #0157 (Aztechs)
Team Role: CAD
LDunnigan is an unknown quantity at this point
Do you have a video of this? I had this idea during our brainstorming but we decided against it, I would love to see it.
Unread 25-01-2012, 13:25
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
My team's actually going for a rotating turret this year, so we have the added difficulty of feeding the balls through a rotating lazy-suzan. To do this, we have the conveyor belt to bring the balls to the top, then a second roller to provide enough "pinch" to stop the balls at the top, and roll them in when we want them. These balls then go directly to the thrower wheel. We still don't have a working example of this, I'll try to get a video up when we do. But if it fails, we have thought about putting in a pneumatic piston to stop the balls and only allow one through at a time. As we're trying to avoid pneumatics unless another need for them arises, we're gonna first try the roller design.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 24-01-2012, 01:18
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Here's a picture of our design:
There'll be a spinning wheel with surgical tubing grabbing the balls and shoving them up to a conveyor belt, with the top of the balls squeezed against something rigid. The balls will go up until the rigid part ends and a spinning wheel beings, which grabs the balls, forces them against a hood (that is movable to adjust the angle) and then out of the robot.
Oh, and the top will move somehow. (We are thinking the hood and wheel will be attached separately on a C that goes to the chassis with a lazy susan that is directly underneath the center of where the balls go from the conveyor to the hood, but that's still somewhat rough.)
Now I'm going to go uninstall the painting program I just downloaded
Unread 24-01-2012, 01:30
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
We're using a system of conveyor belts to both suck up the balls and pull them up to the shooter. They feed directly into the shooting mechanism. You should also take a look at some robots from lunacy and 2006. You'll probably find many different ways that would be effective here.
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 24-01-2012, 01:32
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Magic.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 24-01-2012, 01:35
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Originally Posted by Nick Lawrence View Post
Magic.
-Nick
This sent a shiver down my spine. I think we should all be very afraid of what 1503 puts on the field this year. Then again when you look at their performance last year I guess that would be prudent anyway.
