Go to Post I think the answer you will get will be the same we have been saying since post #2 on page 1. - KenWittlief [more]
Unread 23-01-2012, 04:09
penguinfrk's Avatar
penguinfrk penguinfrk is offline
AKA: Larry
FRC #1899 (Saints Robotics)
penguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of light
FRC1899 Shooter Prototype
As with 488, we reached similar conclusions that using wheels to launch the ball would create too much wobble due to the compression of the ball. Our solution was also similar, using some sort of container or cup to launch the ball with a quick release of energy.
The angle of the rail is at 45 degrees. Due to the limitations of our workspace (ceiling height), we're only using about 50-70% available power/length of the rail, and of course it can be further adjusted by manually changing the tension. The video shows shots fired at 21'.
We were making about 3 in every 4 shots. We made all of our shots when the ball was placed at a certain orientation (FIRST logo face up), but it veered slightly when it wasn't placed face up.
http://youtu.be/3Y3a4f30xXY
Any questions/critiques/suggestions? We'd love to hear some possible improvements to the design.
Larry
Saints Robotics 1899
High school intern at FIRSTWA
2011 Seattle Olympic Regional:
Website Excellence, FIRST Dean's List Award (for team captain Kevin Kimura), Tournament Winner (Thanks 3393 and 2990!), Chairman's Award Winner
Unread 23-01-2012, 09:42
GilaMonsterAlex's Avatar
GilaMonsterAlex GilaMonsterAlex is offline
Lead Team Mentor
FRC #3785 (Gila Monsters)
GilaMonsterAlex is an unknown quantity at this point
Re: FRC1899 Shooter Prototype
Very cool!!! Are you worried about fatigue in the surgical tubing? Also, what about your release mechanism? But still that's awesome!! Great Work!
Unread 23-01-2012, 12:11
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Cool.
Any mechanism ideas for pulling/releasing? Or adjusting range?
Unread 23-01-2012, 12:17
Chris is me's Avatar
AKA: Pinecone
I'm kind of wondering if we should just put three catapults on our robot instead of our existing manipulator now...
Unread 23-01-2012, 12:29
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
An clever way to solve this is not to measure distance, but force. 190 utilized this on the 2010 robot, which had a surgical-tubing powered kicker. We mounted strain gauges on the struts which anchored the surgical tubing, which allowed us to monitor the strain (due to the deflection force provided by the surgical tubing), and correct for surgical tubing deterioration. It also meant that if the tubing ever got too worn out or broke, we could just replace the bands and not worry about getting exactly the same length/tension.
The 2010 application was much less sensitive, and I don't remember if we ever actually used it in our competition code, but we had the capability and proved that it worked. In an application like this where the accuracy is incredibly important, the ability to not have to re-tune your launcher if you have to replace the tubing could be very critical.
Unread 23-01-2012, 12:33
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I can't speak for what 1899 is doing, but I will add that we are semi-seriously considering this. We just need a simple way of making sure they all point at the same place downrange -- and that it's adjustable.
--Madison--
...down at the Ozdust!
Unread 23-01-2012, 12:35
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
That's not a bad way to do it, and it certainly is better than doing nothing, but force != stored energy when the spring rate is changing.
Unread 23-01-2012, 12:40
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
In our experience bungee cords, like the ones you use to tie things down, although not as stretchy as surgical tubing, are much stronger and more durable than surgical tubing, and usually much cheaper.
Jason
Unread 23-01-2012, 13:05
Nuttyman54's Avatar
Mentor, Tactician
You are correct, and I should have been more clear. There was a potentiometer on the system in addition to the strain gauges, which gives enough information to calculate the spring rate at any given time. We found that the surgical tubing was fairly consistent enough in the spring rate that it would have to deteriorate very far before the assumption stopped being accurate enough to make a difference, so I don't think we actually had this particular feature coded. We were using the black thick-walled stuff available from McMaster, very hardy.
As mentioned before, our measure of accuracy wasn't anywhere close to the degree necessary for this year's challenge, so your mileage may vary. I do believe you will be able to be more accurate with a measurement of force/spring rate, but it still might not be enough to have the kind of "drop in replacement" capability we envisioned for 2010.
Unread 23-01-2012, 14:54
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Why not just use a spring instead of the surgical cord. On one end you could add an adjustable buckle to change the tension. Set it and forget it or monitor it and change it for differrent distances.
Roy
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 23-01-2012, 15:08
penguinfrk's Avatar
AKA: Larry
Sorry about the confusion. Point of clarification:
The surgical tubing was just for prototype's sake. We too were worried about the wear on anything with elasticity. Right now, we're considering adding a blade underneath the carriage, and using flywheels with encoders for energy.
My main concern for this design is the complexity. It's a good 3 or 4 stages, form intake, to lifting the ball, to depositing it in the ball cup on the carriage, to the mechanical trigger for the flywheels to make contact.
Larry
Unread 23-01-2012, 15:21
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
All I can really say for 3484 right now is that we are using a similar design in the fact we are launching with a propulsion system instead of the friction launcher due to lack of repeatability. However our design is more incorporating a crossbow using extension springs
Unread 23-01-2012, 17:12
nitneylion452's Avatar
AKA: Joe Lee
3167 was testing a catapult design, but we decided to go with the pitching machine style shooter for 2 reasons: recovery time and space constraints. The way we saw it, there were too many thing that could go wrong with a catapult (ball misses when loaded; it doesn't get pulled back enough, if at all; etc).
But this design seems very nice and consistent. I like it a lot! Keep up the good work!
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 24-01-2012, 02:16
For students interested in the math take a shot at this.
Unread 24-01-2012, 02:56
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
I really like the conceptual idea of using the liner slides plus the surgical tubing. Very simplistic in only having to find the force to propel the ball without having to really account for ball compression and deformation with using a roller type set up. I am very interested to see the final design of the shooting mechanism in the coming weeks.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
