Re: Axis Camera Issue
Yeah it looks like it. Why can't the camera power cable use a wago connector like the router does so you can't accidentally plug it into the 12V terminals?
.The reason is that the camera was built to use a wall adapter, we are using it in a way it wasn't originally meant to be used and thus there was no need to design it to work the way we use it, or any other way really. |
The way the power distribution system was designed, all of the white Wago connectors are for 12 volt power (24 volts to the Solenoid Breakout was an afterthought). The camera power supply is exceptional; it was originally the only 5 volt device in the system, and it uses the special no-connector port so you can't accidentally plug it into a 12 volt supply. |
I was a little disappointed in the "How to Configure Your Camera" section this year. There was a picture of the power distribution board labeled "Camera Power Feed...", which is great that there's a picture, but there were 3 power feeds in the picture (5 if you include the power sources fed via breakers). How is a rookie team to know that it's the 5V source vs the 12V source vs the breaker fed source? They're all in the picture. An arrow photo-shopped into the picture pointing to the proper power source would have been helpful (or a note clarifying that it's the source laveled "5V"). I know that the control system drawings were clearly labeled to show which power source feeds the camera, but just following the "Getting started" document I can see how someone would try to feed the camera from the wrong source. |
I also have a deeply ingrained habit of double-checking power connections and voltage requirements before wiring things up and plugging them in. |
#7
One thing I would like to see is the manuals passed out to a group of high school students that have no FIRST experience and have them try to do the entire setup. That would help catch common errors and questions, and highlight where some clarification is needed. Maybe this is already done, I don't know. |
