Go to Post I suggest that FIRST should include a "big red button" in the KOP next year to make everyone happy. :p - Jay H 237 [more]
Unread 24-01-2012, 09:42
Team 4264 Team 4264 is offline
FRC #4264
Team 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud of
Ribbon Cable broken
Our 37 pin ribbon cable is broken. To order from Digikey you kind of have to know what you need. I was wondering if one of you could toss me a link to a replacement part.
Thanks
Andrew Lawrence
Posts: n/a
Re: Ribbon Cable broken
Same thing happened to us. Odd.
Unread 24-01-2012, 09:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
In what way is it broken? It consists of three parts, do you need all 3 parts or just one? Maybe it could be repaired if you know how?
Unread 24-01-2012, 09:46
FRC #4264
Sadly, not after our freshmen attempted a fix.
Live and learn.
Mark 3138 Mark 3138 is offline
Mark 3138
AKA: Mark Adkins
Mark 3138 is on a distinguished road
Thanks
AndyMark sells them http://www.andymark.com/product-p/am-0672.htm
Unread 24-01-2012, 09:59
MrForbes's Avatar
AKA: Jim
Is the ribbon cable itself damaged beyond use? What about the connectors, is only one messed up, or both of them?
http://search.digikey.com/us/en/prod...37S-ND/1122608
http://search.digikey.com/us/en/prod...37S-ND/1122604
I don't know if these are the exact parts used, I don't have the cable handy to look them up, but this is the kind of stuff you need to order.
The cable itself is kind of expensive if you have to buy a whole roll of it.
Unread 24-01-2012, 10:22
MrForbes's Avatar
AKA: Jim
Or do it the easy way, get a senior to supervise the freshmen when assembling it
http://www.andymark.com/DB37-Flat-Ri...-p/fc12-01.htm
Unread 24-01-2012, 11:03
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
FWIW, we created a ribbon cable for our own use last year. We got the ribbon from our primary supplier (it was actually 50-strand that we cut down to 37) and got these parts:
http://www.newark.com/3m/8337-6000/d...t=3M+8337-6000
http://www.newark.com/3m/8237-6000/d...t=3M+8237-6000
Oddly, it seems they've gone up in price significantly since last year... they were cheaper than what we found on digikey at the time, but apparently not anymore...
