Re: Physics Quiz 8
Could you show your work please?
Re: Physics Quiz 8
Sure. I used a somewhat roundabout method. Let A = F/k be the amplitude of the oscillation. The position will follow simple harmonic motion with equation x = L + A * cos(sqrt(k/m)*t), with x = 0 as the left end of the spring and the mass started at t = 0. So we set x = L2 and so L2-L = A * cos(sqrt(k/m)*t). Also, v = x' = - A * sqrt(k/m) * sin(sqrt(k/m)*t). So then we have v^2 = A^2 * (k/m) * sin^2(sqrt(k/m)*t) = (k/m) * (A^2- A^2 * cos^2(sqrt(k/m)*t)) = (k/m) * (A^2-(L2-L)^2) = ((F^2)/(k*m) - (k/m)*(L2-L)^2). Finally we have
v = sqrt((F^2)/(k*m) - (k/m)*(L2-L)^2). |
Re: Physics Quiz 8
Good stuff.
In post #2, lemiant used energy conservation to find the solution*. In post #6, dan2915 used the equations for simple harmonic motion. Let me add a third way: use Newton's 2nd Law: F = -k*x = M*a = M*(dV/dt) = M*(dx/dt)(dV/dx) = M*V*(dV/dx) => M*V*(dV/dx) = -k*x => V*dV = -(k/M)*x*dx Integrate the left side from V=0 to V=V2, and the right side from x=-F/k to x=(L-L2), and solve for V2 This Quiz was inspired by post #5 in this thread. *neglecting the error in the final step Last edited by Ether : 25-01-2012 at 10:41. |
