It's against my rules to be greater than 80" away from you.
Unread 23-01-2012, 20:44
George George is offline
#0060 (Bulldogs)
George is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to behold
Diffrent Batteries
Hi All
Andy Mark Lists Two different Batteries: NP18 -12 and ES17 -12
Both list about the same spec.
Q; any real difference? Any real life stories?
Thanks
Geo.
watch the oz, the lbs take care of themselfs
Unread 23-01-2012, 21:12
DonRotolo's Avatar
OMGweek5whyarentwedoneyet OMGgetgoin
FRC #0832
Re: Diffrent Batteries
Not really; I believe both are legal this year (I'll let you look it up).
Just note that some of those batteries are older than others. Batteries that haven't been charged every 90 days become damaged, and don't work as well.
Unread 24-01-2012, 11:06
#0060 (Bulldogs)
Hi Don
Thanks for the input
Both batteries are legal
We are looking to purchase extras for this season (and looking for the best / longest life)
There is no way that I know of to check manufactures date before purchase, so I was looking for personal experiences or inside info on these two products;
Being sealed batteries if they sat on the shelf for a year I don’t think they were maintained (charged at 90 day intervals) the suppliers are good guys and if there are any product defects I am sure that would be taken care of, but if a battery drops in performance 3-4 months down the road there is no recourse
Just looking for the best value
Have fun
Geo.
Unread 24-01-2012, 18:49
George,
The batteries are for all intents and purposes identical. You may have to go through a few charge discharge cycles to get them up to peak performance but they should be fine after that. Be sure to keep them from freezing and use only the KOP chargers or equivalent under 6 amp charger.
Unread 24-01-2012, 20:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You may have to go through a few charge discharge cycles to get them up to peak performance.
What exactly happens in this process?
Unread 24-01-2012, 21:17
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Get's the electrons moving! Duh!
No.. but really, it helps remove I believe it's sulfate built up on the plates, which increases the internal resistance, and decreases the amount of umph the battery can provide during heavy loads.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 24-01-2012, 21:32
Just helps to clean a little. In AGM batteries, I believe it will move the things around. As you go through charge and discharge, temperature changes, plates change dimension and the glass mat gets a chance to fit itself back to the plates it lies between. If gravity has pulled things to one side this helps redistribute back to original manufacture. If you have a battery tester like the CBAII, this would be a good time to check the battery. If you think about one of the applications for this battery you will begin to see that it is designed for idle periods. You will find this battery in several of the smaller, two lamp emergency lights. Mostly they just sit on trickle charge, never moving but they do cycle internal temperature and remain good for when they are needed.
