Go to Post Spouting off without all of the facts is a bad idea. It's also bad to envoke the gods of "Gracious Professionalism" to judge others. - Rich Kressly [more]
Unread 24-01-2012, 13:01
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
BaneBot gearboxes out of stock...
So today when I tried to order the 20:1/26:1 gearboxes [for the 550] today I realized both are out of stock...
After calling banebots and getting no answer, anyone know how long before they get back in stock?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 24-01-2012, 13:45
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: BaneBot gearboxes out of stock...
Banebots will be the only one to answer that question. I can provide some related answers you might be interested in, however. Namely, what other options you have.
Andymark has the GEM500 gearbox 13:1 2-stage, 49:1 3-stage. Or the PG-71 gearbox at 71:1.
From Banebots, you could buy all the P60 parts individually and assemble the thing yourself. It's about $25 more expensive (Crazy, I know). I can post a list of all the necessary parts for a 20:1 or 26:1 gearbox if anyone's interested.
In my search for gearbox alternatives last year, I came across some possibilities that I've yet to try. WARNING: These look like they interface to an RS-500/550 based on the gearbox drawings. I can't guarantee that, nor do I know anything about the robustness or reliability. Most have the motor attached, so you'll need to press the pinion off the shaft or find a new pinion somewhere.
Robot Marketplace PK27 (27:1) (sounds spur gear, less robust)
Robot Marketplace PD27M (27:1) (planetary, more robust)
Also possibilities if you can find somewhere to buy them:
http://www.mfacomodrills.com/gearboxes/942d_series.html
Or any gearbox/motor off this page:
http://www.kysanelectronics.com/Prod...p?recordID=247
Unread 24-01-2012, 13:50
Mark 3138 Mark 3138 is offline
Mark 3138
AKA: Mark Adkins
Mark 3138 is on a distinguished road
Ran into the same problem a couple days ago. Those gearbox's are not listed on the FIRST team list of parts. We recalcalculated our need and switched to 775 motors and gearbox's that BB showed available. I would not trust them to get an out of stock order to you in time.
Unread 24-01-2012, 13:55
That brings up another possibility. Order a 775 gearbox plus the correct 550 rear block, mounting kit, and pinion. Still more expensive than ordering exactly the gearbox you need, but a little simpler than ordering all the individual pieces.
Unread 24-01-2012, 14:22
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
This or a comparable bargain brand drill has approximately the ratio you want and mounts a 550 sized motor. These motor mounts will mount the gearbox. This guide explains how to take apart and modify the drill to lock out the slip clutch.
Unread 24-01-2012, 15:14
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Angry Re: BaneBot gearboxes out of stock...
Based on the relatively low price of the 32DP gears that Robot Marketplace lists, I suspect that we'll be self-building the three ~26:1 gearboxes we need. We had planned on using several the P60 26:1 but learned of the backorder status earlier today (independant confirmation). Sigh.
Unread 24-01-2012, 15:23
I just got a few 16:1's and plan to reduce them further. Shouldn't be too bad for now until I can get a shipment of 20:1's in.
Unread 24-01-2012, 21:52
Mk.32's Avatar
AKA: Mark
This is bad news...
I know of a few of the other solutions but we would really rather not have to go moding drill motors or something.
I hope they get some stock soon..
Unread 24-01-2012, 23:17
An interesting update from BaneBots:
PLEASE NOTE: We are currently out of material to manufacture 5:1 P60 planet gears. As a result of this all P60 gearboxes with a 5:1 stage will currently be marked out of stock.
We are having more material made; however, it has a lead time putting general availability of 5:1 gears in the late March / early April time frame.
We are continuing to search for alternative sources of material and believe we have found a few small lots. We hope to make a small number (100 - 200) 5:1 and 26:1 P60 gearboxes available within a week. In the interim we encourage you to look at the 4:1, 16:1, 64:1, and 256:1 P60 gearboxes.
I'll bet that modified drill is looking a whole lot better now, huh?
Unread 24-01-2012, 23:20
Aren_Hill's Avatar
Build Nifty Things
We got our order of 11x 20:1 p60's in today, made sure to order early
A guy who likes robots.
Unread 25-01-2012, 00:29
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Classic Banebots. Will they ever learn that the demand rises hugely during FRC season?
Unread 25-01-2012, 00:47
Mk.32's Avatar
AKA: Mark
Time to start moding those drill motors....
BaneBots are really mainly BANE
Unread 25-01-2012, 00:57
AdamHeard's Avatar
Lead Mentor
We have a lot of new, unopened cimulators if anyone needs them down the road.
We also have a surplus of used 4:1s if someone was really in a pinch.
Unread 25-01-2012, 01:02
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
I don't know your specific application, but wouldn't 16:1 be comparable to those other 2?
Unread 25-01-2012, 01:05
Mk.32's Avatar
AKA: Mark
This is what we will probably have to do..
But the difference is about 1000 vs 650 RPMS.
