Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
Unread 24-01-2012, 13:31
helluvatizzy helluvatizzy is offline
AKA: Helen Zha
FRC #4302 (Robophins)
helluvatizzy is an unknown quantity at this point
what's the best way to connect an axel to a drive wheel?
What are good/feasible/easy options for connecting an axel to a drive wheel? And what are the pros/cons of each?
Press fit? Use key stock and a grooved shaft? Create a flanged hubcap of sorts that actually bolts through the wheel?
We're a rookie team with pretty minimal machine capabilities, so we'd appreciate input!
Unread 24-01-2012, 13:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: what's the best way to connect an axel to a drive wheel?
What's the application for? It makes a big difference.
Unread 24-01-2012, 13:38
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Try an hub from AndyMark, they bolt on to all of the AM wheels [including kit].
They have options for keys and hex.
I would NOT use a press fit for a drive wheel.
If you give us more details on what this is for, we can help you more.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 24-01-2012, 13:39
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Have you considered driving with a dead axle? This is like the kit bot if your team took the time to look at that. Basically a wheel has bearings on it that allow it to rotate freely about its axle with very little friction. Then you can bolt sprockets (or gears) to the wheel itself and drive that sprocket with chain running from the motor (or other gears). This may be easier to do/easier to find with limited resources.
For live axles where the axles actually drive the wheels, many teams use hex shafts. This might be tough to do with limited resources, but the COTS stuff is out there.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 26-01-2012, 12:43
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
If you wanted to do a live axel, you could order long hex output shafts from andy mark and run the axel through your frame with a hex bearing block holding the other end, but really, dead axels with chain and sprockets gives you more flexibility for gear ratios and it's alot easier with limited resources. http://www.andymark.com/product-p/am-0396.htm- these just drop right into the andy mark toughbox minis (if that is what you're using)
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
