Go to Post CD has a vast store of knowledge, information, and wisdom. Add to it. - JaneYoung [more]
Unread 24-01-2012, 15:23
Cap'N Cap'N is offline
FRC #1711 (R.A.P.T.O.R.S.)
Cap'N is an unknown quantity at this point
Re: Keyang Motor Spur Gear Pitch
So far I have found out that Dimetral pitch is equal the number of teeth devided by the circumferance of the pitch diameter.
Unread 24-01-2012, 21:35
hey I found the info you were looking for its on us first webpage all you have to do is search keyang and a motor spec sheet sshould pop up as a result
Keyang Motor Gear Profile LieAfterLie Motors 6 23-02-2007 17:16
Keyang Window Motor Gear pitch AdamHeard Technical Discussion 3 19-01-2007 12:12
Spur Gear Rod? David Guzman Technical Discussion 6 18-01-2006 22:53
gear pitch BoticsPUNK Motors 2 19-01-2003 16:53
Window Motor Output Shaft Spur Gear Specs archiver 2000 1 23-06-2002 22:56
