Go to Post ...I've changed my position. I'm fully supportive of Joe's suggestion... - Chris Hibner [more]
Unread 23-01-2012, 16:13
Keylime Keylime is offline
FRC #4283
Keylime is an unknown quantity at this point
PWM out ports confused
Hello. I am from a rookie team, and we are having trouble with our digital sidecar. Our PWM out puts are mixed up- on the program (we are using the labview default) it says it is connected to port 2, but really it is connected to port 3. Also, when it says it is connected to port 4 it is connected to port 1. Does anyone know how we might figure out which port is which aside from simply testing every output, and does anyone know what's going on with our sidecar? thanks for your time
Unread 23-01-2012, 22:09
alancop's Avatar
alancop alancop is offline
200mph club member
AKA: Alan Copeland
FRC #1716 (Redbird Robotics)
Team Role: Electrical
alancop is an unknown quantity at this point
Re: PWM out ports confused
Check this document and see if your DB37 cable is broken, I have a seeking suspicion that it is.
Unread 23-01-2012, 23:04
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Does your robot signal light blink? If not, your DB37 cable is broken.
Unread 24-01-2012, 10:05
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
It really must suck for rookie teams when problems like the ribbon cable crop up - you just don't expect something like that to be wrong, and just assume you're doing something wrong. A veteran team, on the other hand, would likely *know* that the code is correct, and start swapping out components with spares from previous years, eventually discovering the cable is bad, and then hopefully finding the document on how to fix it.
FWIW, our cable was bad as well, and it really is rather easy to fix. The instructions FIRST posted are great!
Unread 24-01-2012, 10:53
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
We were helping out a Rookie team at the Stl Science Center on Sunday and they were having a problem with their RSL light/RSL indicator on the Sidecar, neither would flash. The first indication to me was the Ribbon cable issue. They were using the new Ribbon cable but had not fixed it, as they didn't hear about this issue. We swapped our DB37 cable with theirs and the RSL came on immediately. It is interesting though because their drive was working* (although I don't know for sure if their PWM channels were flipped as well) but after the cable swap their drive was working normally. Interesting failure mode for the Ribbon cable.
Unread 24-01-2012, 11:24
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
To anyone reading this topic: Please remind all other teams you know to read the Team Updates. This info was covered, but not every team (especially rookies) know that there are updates. This is a great reach-out that can be a starter for team-team help and communication in your region.
Unread 24-01-2012, 15:27
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
We (as a rookie team) ran into the cable issues (not sure that is your problem, but could be). We had flipped 1 end (to fix the KOP packing mistake which is mentioned in the Team Updates), but hadn't managed to press the connection all the way on. As a result, the pwms never seemed to output anything.
Key thing to look for is the little led next to the "RSL" connector. If the cable is working, it should flash continuously once the cRIO is started up.
Unread 03-02-2012, 16:05
HALthewise HALthewise is offline
FRC #4283
HALthewise is an unknown quantity at this point
Thanks a lot guys. The ribbon cable was our problem, as we found out after testing three different sidecars. I have read all the team updates, but apparently didn't pay enough attention to the small paragraph about the ribbon cable. Not being familiar with part numbers, the phrase "DB87" didn't remind me of the ribbon cable.
