Go to Post Sleep... what is this sleep you speak of? - Choi9111 [more]
Unread 19-01-2012, 10:59
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
Re: Laying it all out there
Team 4264,
Our rookie year was 2003 and we used castors and two driven wheels in the back...ours worked great! Its not the best drive system, but it does work, its cheap, and that year our torquey drive system allowed us to make Semi-finals at GSR because we 0wned the slick ramp. Keep it geared low and you'll be fine. If you want to climb the median, some 8-10" bicycle wheels on the back should allow you to climb over, maybe add some deflector plates around whatever castors you use. Ball casters (we used them twice) will do worse than regular castors on the median. Regular castors will twist to get over, but ball castors will likely get ripped off.
I would use a CIM motor on the ball shooter with direct drive. Certainly better setups, but our tests with a simple, one-wheel pitching machine and a CIM direct to the shaft worked pretty well. Put that bad boy on a jag and you should be able to score some points.
And I agree with the other teams, reach out to your local teams and reach out to your inspectors. Robot inspection is more stringent than bridge inspection (I build bridges, and its true) and yes, the process is iterative. The judges will help you, and getting a prelim opinion on the things you have to fix is a great strategy for anyone!
Good luck! Feel free to send me any questions,
Jim, EIT
Unread 19-01-2012, 11:36
zachmartin1806's Avatar
zachmartin1806 zachmartin1806 is offline
FRC #1806 (S.W.A.T. Robotics)
zachmartin1806 has a spectacular aura aboutzachmartin1806 has a spectacular aura aboutzachmartin1806 has a spectacular aura about
I highly recommend you go and watch 1114's Kitbot on Steroids presentation, the configuration can be set up for a narrow or wide side pick up and uses nothing but the kit of parts. Trust me it works very well and fairly easy to program (as far as programming goes). If you need anything don't hesitate to ask the CD community, you will get many great answers. Good luck this year!
2013 - Greater Kansas City: Regional Winners (1986, 2457), Judges Award; Oklahoma City: Regional Winners (1986, 2389)
2012 - Oklahoma City: Innovation in Control Award
2011-10,000 Lakes: Dean's List Finalist , Coopratition Award
2010 - St. Louis: Regional Finalists (1098, 1329)
2009 - Greater Kansas City: Regional Winners (1208, 931), General Motors Industrial Design Award; St. Louis Regional: General Motors Industrial Design Award
2008 - Greater Kansas City: Regional Winners (476, 1802), Johnson & Johnson Gracious Professionalism Award; Oklahoma: Regional Winners (2165, 2354), Motorola Quality Award
Unread 19-01-2012, 12:25
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
in my opinion as a new team create just a kit bot but give it the ability to go over the bridge and practice balancing so u get points. and get 2 more cims to make a better drive train
Unread 19-01-2012, 12:27
A lot of other people prefer that rookie teams at least take a shot at doing something other than just being a brickbot that plays defense. Which is exactly what these guys are doing: trying to get a scoring mechanism going.
Unread 19-01-2012, 12:56
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Build the kit bot (for drive). Simple, easy, effective.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 19-01-2012, 13:38
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Originally Posted by Team 4264 View Post
4264,
Check your private messages; We might be able to help you out.
-roger
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 19-01-2012, 16:12
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Originally Posted by squirrel View Post
You can probably get by with a single motor/wheel shooter, have the ball go over the wheel, that will give it backspin and make it more likely to land in the basket. One FP motor is sufficient, and you probably want a single stage of gear reduction...see if you can modify the plastic FP gearbox to do this. We've done it by just using the first plastic gear stuck in a box we made ourselves, but without some machining help it would be pretty difficult. See if you can find any kind of machine shop that might help you
We are considering using the plastic FP gearbox (for our collector) because one of our mentors thinks it will be easy to connect to PVC. Did you actually use the gearbox or did you just cannabalize it for the gears, and if you actually used, could you give me some feedback on how to interface into the gearbox's input and output? (or alternatively tell me that if its a bad idea)
Unread 19-01-2012, 20:48
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Originally Posted by fox46 View Post
Just because you aren't in a rural area doesn't mean there aren't knowledgable individuals and businesses who are willing to help in your midst. You guys have to get out there and find them and I bet they would love to help you- sometimes all it takes is asking.
One of our Hall of Fame teams, Cybersonics (103), also runs a FIRST rural support network. I bet they'd also be happy to help you out in whatever ways they can. They're in Pennsylvania (a town 60% the size of yours, actually), but they're an amazing team in all aspects and have built up an astounding resource network and knowledgebase.
Unread 24-01-2012, 10:34
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Siri,
Thank you very much for all of your compliments. I will PM the team in need to see where we can help. To anyone in need of help in anyway, rural or non-rural, please let me know. FIRST is the hardest fun you will have and we are always willing to help.
Cassie
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 24-01-2012, 16:30
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Don't forget that scoring on the bridge can bring your alliance 10-20 points if on your alliance bridge or up to 2 Qualifying Points on the co-op bridge in the center, so even without a ball scoring mechanism, just getting up on the bridge to balance has a lot of value.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 24-01-2012, 21:00
DonRotolo's Avatar
Back to humble
FRC #0832
Legend tells of a bot from rookies of the past brought in with no programming to compete yet the kind competitors swooped in and saved the day by programming it before the event.
Well, yes, it happens all the time, but let's try to avoid as much of that as possible while there is time.
BUT: If you do show up at competition without a fully-functioning robot, ASK FOR HELP IMMEDIATELY. Teams will be tripping over each other to help you get up & running.
You might be happier with a 4-wheel system, using chain to drive the back wheels from the same motor as the fronts. But we did use ball casters one year, it wasn't awful, but our drivers had to practice a lot to get good at it. Oh, and they get gunked up a lot, clean them after every 2-3 matches.
Don't diss those FP motors, they sure do look wimpy but they're very powerful. But if you stall them (apply power while the shaft can't move) they'll let out the magic smoke very quickly.
Keep asking ANY and ALL questions here on CD. All of us are problem solvers for fun, and we'd love to get a shot at solving yours.
Unread 24-01-2012, 21:50
Team,
I only have a few minutes so I haven't read all the posts if this has been stated already. If you have any plans of going onto the bridge, casters are the worst thing you could try. While they could be made to work OK on flat floors you cannot control them on a sloped surface. Teams have ignored this warning in the past so I will tell you that once you find the casters a burden, you can fix the position of the wheel. Just drill a hole through the plates of the caster, insert a screw and nut to lock the rotating pieces and turn the casters into non-rotating wheels. We abandoned casters in '98 and that played on a flat floor, never to be resurrected.
Unread 04-03-2012, 13:39
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Well, so far you guys have really busted our design bubble about the FP motors so I'm just going to lay it all out and see what you think. Let me remind you that we are the rookie rural school with absolutely no help. No mentors, no engineers, no clue, no time, and not enough students (4-6 regulars), but we are going to build a bot!
<snip>
You must regale us now with the story of your run to the FINALS!!!
Congradulations. Hope you had a great time.
Software Mentor
3853 Pridetronics[
