Go to Post It's wrong to scuttle someone else's boat because you don't think it's seaworthy. You probably don't know that what you were seeing will be called a submarine. - ThatHat [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 01-24-2012, 06:09 PM
daOyster daOyster is offline
FRC #2053
daOyster is an unknown quantity at this point
Can't get the 2CAN to work or access the web server
Our team decided to switch to CAN bus this year and wanted to use the 2CAN.
I have followed the directions to setup the 2CAN but it still doesn't work. It won't let me access the web server. It is always blinking fast orange too if that helps. The software utillity also detects it also. We have it flashed to 2.21 and
the rev-66 plugin for the cRIO loaded too.
