Go to Post Didn't you know? Kids today are born with GPS tracking systems installed so Mom's can look them up on Google Earth wherever they are and also know what they're doing for a living, eating the right foods and if they're dating the appropriate people. - Koko Ed [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 01-24-2012, 06:09 PM
daOyster daOyster is offline
FRC #2053
daOyster is an unknown quantity at this point
Can't get the 2CAN to work or access the web server
Our team decided to switch to CAN bus this year and wanted to use the 2CAN.
I have followed the directions to setup the 2CAN but it still doesn't work. It won't let me access the web server. It is always blinking fast orange too if that helps. The software utillity also detects it also. We have it flashed to 2.21 and
the rev-66 plugin for the cRIO loaded too.
Unread 01-25-2012, 12:36 PM
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Can't get the 2CAN to work or access the web server
Make sure your computer's IP settings are correct. The 2CAN will still appear in the firmware utility even if the IP settings are different. The firmware utility uses a broadcast message to detect any 2CAN's on the bus. In order to open the web dash you need to make sure that the pc is on the correct subnet. The firmware utility can do this for you if you select "generate settings from 2CAN".
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 01-25-2012, 10:48 PM
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
We figured it out. The web browser usually uses a proxy server. We had to uncheck this in options in IE.
