Go to Post Ken Patton rocks my socks off! - Josh Hambright [more]
Unread 24-01-2012, 21:03
bmxer51 bmxer51 is offline
FRC #2874
bmxer51 is an unknown quantity at this point
DeWalt Drill Motor
We have a delima. My teacher says that we can use a dewalt drill with the dewalt motor straight off the shelf as it is a COTS item. However, I believe that the use of this motor doesn't fit into the rule on the limitations of motors. Who is right?
Unread 24-01-2012, 21:07
Re: DeWalt Drill Motor
[R48] bans the motor from being used.
However, the gearbox is legal, provided that you put an FRC-legal motor into it.
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Under NO circumstances can you violate the motor rules.
If by some completely wild chance the dewalt drill had a 775 or 550 motor that they bought from banebots then you are good to go. In reality it doesn't have that motor so you have to pull the motor off and replace it.
A COTS item doesnt' make the motor rule go away.
Ed Barker
Unread 24-01-2012, 21:10
FRC #2874
Thank you all! You are a tremendous help! I knew i was right.
Unread 24-01-2012, 21:40
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Here's an excellent resource about interfacing FIRST legal motors with the Dewalt gearboxes.
http://www.chiefdelphi.com/media/papers/1592
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 24-01-2012, 21:44
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: DeWalt Drill Motor
Some DeWalt drill transmissions mount a 775 frame. So if you pull the pinion off the DeWalt motor, and press it on the legal 775 motor, you will have a quick, legal conversion.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
