Go to Post The numbers that I gave were purely theoretical and should not be considered realistic - Karibou [more]
Unread 24-01-2012, 08:06
hsekhon27 hsekhon27 is offline
FRC #0280 (TNT)
hsekhon27 is an unknown quantity at this point
Setting RPMs on motors
To get an accurate trajectory on the ball, I wanna preset the RPMs on the shooting motor. I know you can just put in integer values like 1 for the motor speed, but what do these numbers mean? 1 meaning 1000 RPM?
Unread 24-01-2012, 08:19
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
Re: Setting RPMs on motors
The output 0-1 is just a power value, 0 being stopped 1 being full power. To do RPM control you need some type of feedback, like an encoder.
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 24-01-2012, 08:21
The numbers -1 to 1 only refer to the battery voltage as it is at the moment.
It won't give you a specific RPM and will vary as you syphon power off to other motors (like your drivetrain), and as your battery gradually depletes itself during a match.
To get a consistent RPM you will need a feedback sensor and what's called a PID software loop to maintain a set RPM.
For feedback you can use an encoder (some come in the Kit of Parts), or a light sensor that counts the passing of a marker on your spinning shooter wheel, or various other types of measuring sensors/devices.
Unread 24-01-2012, 12:22
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
If you are using CAN with Jaguars, then you can easily set speeds using their built-in control feedback loop system and plugging your encoder into your Jaguar. For Java, see the CANJaguar javadocs, and note the "control mode" variable, which you can set to kSpeed, setPID(), and set() method. You will have to tell it how many encoder codes your encoder will report per revolution as well.
If you want to see an example of making your own feedback loops for Victors, you can check out a (Java) class we wrote last year to do this here.
Unread 24-01-2012, 14:15
Have you successfully done this?
Unread 24-01-2012, 16:04
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Here is a picture of periodic task that we have run on our test platform. It seems to perform quite well for maintaining desired RPM. YMMV.
The simple explanation is that we are using this like the "I" function in PID. This runs 100 times per second.
The 250 multiplier/divisor is found by reading your maximum rate count without feedback at full speed.
Name:	Rate control.JPG
Unread 24-01-2012, 16:24
Plus feedforward.
Unread 24-01-2012, 21:46
FRC #0280 (TNT)
Okay I have never programmed an encoder before and I'm confused by the begin vi. Can someone please post a sample code for an encoder to set the desired RPMs? Thanks
Unread 24-01-2012, 22:33
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
We have!
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 24-01-2012, 23:21
Originally Posted by bhsrobotics1671 View Post
We have!
With a drivetrain too? Or just a free-spinning wheel?
Unread 24-01-2012, 23:32
pfreivald's Avatar
AKA: Patrick Freivald
Our plan is to use the kit encoders direct-mounted to our flywheel shafts. Does anyone know if the manufacturer claim of up to 10,000 rpm is accurate? We'd rather not add the weight, complexity, and inefficiency of having to gear down an idler for the encoder to take rates.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 24-01-2012, 23:50
FRC #0280 (TNT)
Just the wheel
Unread 25-01-2012, 00:18
Alex Carrillo
Define "success." We did it on our drivetrain last year, with each wheel being controlled separately, and tuned the values using BDC-COMM. Were we able to control the speed of the wheels comfortably? Yes. But we faced typical Jaguar reliability issues that led us to replace them with Victors + homebrewed speed control code.
Unread 25-01-2012, 08:33
Define "success."
In this context, I guess I meant:
- did you measure the actual steady-state output speed and confirm that it was indeed equal to the speed you were commanding?
- was it stable?
- was the dynamic response "good"? (I know, define "good". How about a rough estimate of step response compared to voltage mode or %Vbus mode)
- for a given speed command, did the controller hold the same output speed under different loads?
The reason I ask is that if you were successful, the folks at this thread would like to hear about it:
http://www.chiefdelphi.com/forums/sh...d.php?t=100135
Unread 25-01-2012, 10:08
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
You can use a PID Controller and use RPM as the unit.
