Go to Post "Individual": I am the FMS. I don't want to talk to you. Robot: FMS, is this true? I still have stuff for you. Actual FMS: No, what gave you that idea? Are you feeling ok? Repeat. Field Monitor: FTA! We need a counselor! - EricVanWyk [more]
Unread 24-01-2012, 22:18
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: labview Drive Programming, 2 Joysticks, 4 Motors
If you wire your Open 4 Motor to a Drive RefNum Set and give it a name, you'll be able to use a Drive RefNum Get to open it. You'll then wire the two axis from your joysticks to the tank drive module. Moving from two to four motors takes a bit of logical thinking in terms of what goes where, and what should do what. It's best to do the coding in front of your bot.
