Re: Sensor Wiring
You have to use an analog signal. To wire, you just solder a pwm cable to three of the outputs on the sensor. Here's the order:
Black-GND Red- 5V White- AN And the female end of the pwm cable connects to one of the analog inputs of the analog module of the cRIO (probably slot 1) |
