Go to Post There was no real separation between who did what. "we" did it all and it was fun. - Team2339 [more]
Unread 24-01-2012, 18:10
Tub Tubs Tub Tubs is offline
FRC #3049
Tub Tubs is an unknown quantity at this point
Sensor Wiring
i am curious as in how to Wire our LV-MaxSonar-EZ1 ultrasonic Sensor
Unread 24-01-2012, 18:38
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Sensor Wiring
Google is your friend.
Unread 24-01-2012, 22:28
hsekhon27 hsekhon27 is offline
FRC #0280 (TNT)
hsekhon27 is an unknown quantity at this point
Re: Sensor Wiring
You have to use an analog signal. To wire, you just solder a pwm cable to three of the outputs on the sensor. Here's the order:
Black-GND
Red- 5V
White- AN
And the female end of the pwm cable connects to one of the analog inputs of the analog module of the cRIO (probably slot 1)
Unread 25-01-2012, 10:18
Superllama12's Avatar
Superllama12 Superllama12 is offline
Wombaticus
AKA: Brandon Buncher
FRC #0540 (Talon 540)
Team Role: Electrical
Superllama12 is an unknown quantity at this point
Re: Sensor Wiring
Black-GND
Red- 5V
White- AN
Yup, we've tested and it works; however, programming-wise, it is kinda weird. We found a website that told us to wire it through the ECHO and/or PING modules, but we can't find anything about what those actually are. Lastly, though we haven't tried it, you should be able to wire the white wire to PW and put the female in DIO, but again, we haven't tested it. Good luck!
I would put a signature here, but that's too mainstream
Wait a moment...
Unread 25-01-2012, 10:40
Re: Sensor Wiring
ECHO & PING are for a different make/model of ultrasonic sensor.
The MaxBotix that came in the 2012 Kit has a couple of wiring options, the analog probably being the easiest.
In code it gets treated just like any other analog sensor.
Read the analog value, convert to inches.
It can also be wired for digital and plugged into the sidecar.
There are code examples for both analog and digital from the LV Start page under Support -> Find FRC Examples..., then Sensors->EZ1...
Unread 25-01-2012, 10:51
robotfreak664+2's Avatar
robotfreak664+2 robotfreak664+2 is offline
AKA: Marquel
FRC #3397 (Robolions)
robotfreak664+2 is an unknown quantity at this point
Re: Sensor Wiring
the wiring instructions should be with the sensor...
Unread 26-01-2012, 12:26
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Re: Sensor Wiring
http://www.maxbotix.com/articles/016.htm Easy as 3.14159265..... Oh, use the analog ourput pin, and get the voltage from the analog breakout in the code, then use the scale factor in the above link to get your distance in the code. The voltage and distance for this unit are proportional.
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 26-01-2012, 13:45
xisybyl xisybyl is offline
FRC #3648
xisybyl is an unknown quantity at this point
Re: Sensor Wiring
Presuming you are using LabVIEW:
1. Bring up LabVIEW
2. Click on SUPPORT
3. Click on Find FRC Examples . . .
4. Under FRC Robotics - double click on Sensors
5. Double click on EZ1 MB 1010 Sonar Digital.lvproj
6. In the project window double-click on EZ1 MB 1010 Sonar Digital.vi
Before you run the VI, right-click on Properties and change the IP address to one for your team.
