Go to Post Our robot weighed 168lbs..... bring it on Trimspa!!! - slickguy2007 [more]
View Poll Results: Is a turret the best way to go for Rebound Rumble?
Yes 174 68.77%
No 79 31.23%
Voters: 253. You may not vote on this poll
Unread 24-01-2012, 07:18
Jared Russell's Avatar
Taking a year (mostly) off
Re: Poll: Turrets for Rebound Rumble
Originally Posted by Madison View Post
Here's something one of our members put together showing the relationship between distance and accuracy.
I will leave it to others to determine if a turret is necessary, but the precision required to sink shots from long distances is substantial.
It may be possible that hitting the backboard and bouncing balls in will be more forgiving. We don't yet have good data on that.
This is a great table. That said, achieving sub-1 degree azimuth accuracy does not in itself necessitate a turret.
Unread 24-01-2012, 14:19
pfreivald's Avatar
AKA: Patrick Freivald
True enough; though the rest of the information is correct. Teams will need to aim with high precision for long shots. I think folks are grossly underestimating the difficulty involved here.
Right-o. I think that the difference between passable teams, great teams, and awesome teams will be accuracy at range...
...and accuracy at close range is better than innaccuracy at long range (except for certain feederbot applications).
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 24-01-2012, 14:55
Bob Steele's Avatar
AKA: Bob Steele
Originally Posted by compwiztobe View Post
We talked about a turret for many of the reasons already mentioned, and we have done it before and it would be fairly trivial to implement.
In my experience... nothing is trivial....
Unread 24-01-2012, 15:00
Chris is me's Avatar
AKA: Pinecone
If you don't have your design down at this point and you read one sentence on Chief Delphi, read this one.
Unread 24-01-2012, 20:42
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Our turret so far. The plywood disc sits on a 6" lazy susan bearing. The ball is fed from the side. The shooter sits on top of this. The turret only moves a little bit, like 45 degrees. The belt is screwed to the wood disc. The pulley on the gearmotor had it's hole opened up to 10mm to fit the gearmotor shaft. Design calls for about one second to move 45 degrees, so we have about an 8:1 ratio, with the roughly 1 rev/second gearmotor.
Unread 24-01-2012, 21:16
pfreivald's Avatar
Looks nice! Are you just using friction for the drive belt, or are you going to put teeth on the plywood disc as well?
Team 1551
I write books, too!
Unread 24-01-2012, 21:27
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Personally, i don't think a turret is needed for this game, it adds a variable that drivers have to more actively control. that is not to say it can't be a useful asset, but if you don't have the driver practice time to dial them in, than i believe it can be more of a hinderance to team performance, than a help.
a driver that simply drives to a certain spot on the field and points the chasis in the right direction will have a lot more success than a driver going to random locations, dialing in the shooter speed and pointing a turret in the right direction. i think many turret teams will find that they do the same thing as the non-turret teams, because their drivers can't get all the variables down consistently.
that being said, one area where turrets could be useful is on defense... a turret team driving in the backfield with turret pointed toward your end. the chasis is driving, turning and picking up balls while the turret just keeps shooting them to your end.
Unread 24-01-2012, 22:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Jim -- you could use Ethernet cable for your sensor wire there. Might tidy things up a bit and be easier to manage. Big spools are much cheaper (per foot) than what you'd get at a electronics store. The school's IT department may also have some spare you can use (10' should be enough). No need for connectors, just splice the twisted pairs like any normal wire. We did that for our 2 limit switches + 1 encoder last year on our wrist joint and it worked great.
GitHub
Unread 24-01-2012, 22:56
MrForbes's Avatar
AKA: Jim
On our turret, the belt was cut to the right length, and the ends screwed into the plywood disc. There's no need for much rotation, so we didn't make it so it could rotate much.
We are planning to use the turret for computer controlled aiming with the camera, so the drive just parks the robot so it's facing the goal, and the robot does the turret turning to "fine tune" the aim right at the basket. The idea is to make it easier on the driver, not more difficult.
I'm not in charge of wiring, but I'll suggest that to the electronics team. For now they just grabbed some old limit switches and wire to get it working.
Unread 24-01-2012, 23:05
pfreivald's Avatar
Gotcha! I was wondering because the addition of teeth would have added accuracy over just tension on the belt -- looks like you've got that taken care of with the drive sprocket.
Team 1551
I write books, too!
Unread 24-01-2012, 23:21
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
I think you're mixing up the width with the position. The key is 144 in., or 12ft, from the Alliance Station wall, and 48 in, or 4 ft deep. So 12 to 16ft.
I'm sure that's where they got the number, but if you put your back wheels on the front of the key, and aim for the center of the basket, you're looking at about a 9 foot shot anyway.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 24-01-2012, 23:37
MrForbes's Avatar
AKA: Jim
Video of a turret in action, but not connected to a shooter yet.
http://www.youtube.com/watch?v=Hu2llOOlR18
Unread 24-01-2012, 23:42
Andrew Lawrence
Posts: n/a
Looks great! The AndyMark gearmotor will probably be our choice of motor for our turret, too.
Unread 24-01-2012, 23:44
Austin2046's Avatar
if you're going to have a camera system auto-aim your turret, you can have a camera system auto-aim your robot.
Unread 24-01-2012, 23:45
MrForbes's Avatar
AKA: Jim
Yeah....maybe if you have a drivetrain that works a bit better than ours will.
