Go to Post Minnesota could pioneer the idea of suspending a field 20 feet above the other field and have true double decker events. - PayneTrain [more]
Unread 24-01-2012, 20:33
grantf's Avatar
grantf grantf is offline
Software Engineering Mentor
FRC #4061 (SciBorgs)
grantf has a spectacular aura aboutgrantf has a spectacular aura about
Subsystem::GetName() Doesn't Do What I Expect
Here's some code and expected versus actual results. I'm confident that WPILib would benefit from an update.
The Test Code
MyRobot::RobotInit()
    // The class called "MySubsystem" derives from Subsystem and calls the
    //  parent class constructor, with a Subsystem name of "MySusbsystem"
    Subsystem* p_subsystem = new MySubsystem();
    // This code prints the name of the newly-created subsystem to the
    //  DriverStationLCD.
    DriverStationLCD* p_driver_station_lcd = DriverStationLCD::GetInstance();
    p_driver_station_lcd->PrintfLine(DriverStationLCD::kUser_Line1, "%s", p_subsystem->GetName().c_str() );
    p_driver_station_lcd->UpdateLCD();
The Expected Result
After I compile this code and download it to the cRIO, I expect the DriverStationLCD to have a single line of text showing "MySubsystem".
The Actual Result
Instead, I see "Subsystem". If I change the name of the passed-in subsystem name to anything else, I always see "Subsystem" as the returned string.
My Suspicion
Subsystem::GetName() is returning a hard-coded value and not the user-provided name.
Please provide an update to the WPILib that solves this problem
Unread 24-01-2012, 22:06
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Subsystem::GetName() Doesn't Do What I Expect
Originally Posted by grantf View Post
My Suspicion
It is returning a hard-coded value. Here is the source code of the function:
std::string Subsystem::GetName()
        return "Subsystem";
Unread 24-01-2012, 22:57
grantf's Avatar
        return "Subsystem";
Indeed, I imagine that the root cause of the issue is that the code from the Subsystem::GetType() method was copy-pasted into the GetName() method - you can see the implementations are the same.
Just in case someone is interested, we implemented a workaround where we simply introduce another intermediate sub-class of Subsystem that extends the GetName() method and returns a local copy of the name. When the WPILib is updated to correct this issue, we will remove our intermediate class.
Unread 24-01-2012, 23:44
The fastest way to get this fixed would be to report a bug in the WPILib Tracker and provide a patch.
Unread 25-01-2012, 01:03
grantf's Avatar
Thanks for that, but it seems I cannot create an account. That pages gives me a bunch of errors regarding password strength, such as "must have at least one number", "must be at least 6 characters long", etc. I have complied with each and every error message with a new password, and still I cannot get in.
I would gladly contribute a patch, but I simply cannot become a member of the project. Bummer...
Unread 25-01-2012, 01:05
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
The password strength requirements are VERY harsh. ALL of these are required in your password:
* Uppercase
* Lowercase
* Numeric
* Non-numeric-non-alphabetic (symbols)
bob
Unread 25-01-2012, 01:17
grantf's Avatar
* Uppercase
* Lowercase
* Numeric
bob
They certainly are. After applying the Fort-Knox password generator, I'm in. Thanks for that
