Go to Post FIRST, for me, is about mental wrestling with oneself through the ideas of others and learning through this dialogue. - sammyjalex [more]
Unread 24-01-2012, 23:57
y-aji y-aji is offline
FRC #3734
y-aji is an unknown quantity at this point
Re: Can't finish drivetrain?
Originally Posted by Kevin Sevcik View Post
The axle holes in the C-Channel aren't exactly in the center of the channel. When you assemble everything, this means the holes are closer to the top or bottom of the frame. One or two of the channels on your tight side might be upside down relative to your loose side. The easiest visual check is to look at the one hole that's out of line with the rest. Make sure it's shifted in the same direction on all your channels. The correct direction is probably down, which puts the rest of the holes closer to the top of the frame.
My oh my that would do it. We'll check that tomorrow.
@aeniug2: we are making a ball collection facility, so we opened the front side of the drive train chassis up to allow the ball to pass through. So, we cut out the front of the robot. That said, it compromises the integrity of the robot to a moderate degree as you no longer have a full square chassis to build the robot on top of. Does that make any sense?
