Go to Post If we miss in autonomous, the team blames the programmer, If we miss in teleop, the team blames the drivers - Jared Russell [more]
Unread 24-01-2012, 20:59
WillF WillF is offline
Team Captain
FRC #2945 (B.A.N.G (Bolts and Nuts Gang))
WillF is an unknown quantity at this point
How to attach axle to FisherPrice gearbox?
http://www.andymark.com/FisherPrice-...-p/fc12-70.htm
Hello fellow robotics people,
We were hoping you could help us figure out how to attach an axle to a FisherPrice gearbox. It would be very much appreciated. The gearbox we are speaking of can be found in the link above. Every year we get one of these in the kit of parts, and every year we are unable to figure out how to actually use them. Is there a standard method of attachment? If so, what is it?
Thanking in advance,
Team 2945
"Light a man a fire and he will be warm for a day. Light a man on fire and he will be warm for the rest of his life..." -Terry Pratchett
Unread 24-01-2012, 21:03
Re: How to attach axle to FisherPrice gearbox?
There's a pretty good one that's been used for a while.
If you look at the inside of the output gear, you'll see that there's a geometric shape. Cut a block of material to that shape, with a keyway or hex or whatever your preferred axle or other power-moving device uses, and put that in. Use setscrews and/or a hose clamp to keep it in place.
Unread 24-01-2012, 22:51
Cem8301's Avatar
Cem8301 Cem8301 is offline
Carolyn
AKA: student president
FRC #3413 (Mad Cows)
Cem8301 is an unknown quantity at this point
We used a hexagonal PVC piece that we bought from our local hardware store. To ensure the rod spins we carefully drilled through the PVC and the axle and put in a pin. This worked pretty well for us. I hope this picture helps:
The steaks are high. Prepare for udder destruction!! <3 Mad 3:O's
Unread 25-01-2012, 01:03
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
The original hub from the Fisher Price vehicles provides an easy way to connect to the transmission output shaft. Search for either of these part numbers:
74570-2239 or 74460-2249.
Drill out this plastic hub to 1/2" and screw it to a turned down v pulley or some thing else that can be a hub with a keyway.
Prior to 2005 or 2006, these hubs were included in the KOP.
Unread 25-01-2012, 01:16
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Last season we found a description of an interface here on CD and re-created it ourselves. I wish I could find the link, but no luck.
It is created by drilling a circular hole with the same diameter as the transmission output. The holes are the same diameter of each finger, or tab, on the transmission. We then drilled and tapped for a 1/2" shaft. Finally we cross drilled through the entire assembly.
We ran this through one regional, Nationals, Cal Games and MadTown and NEVER once had a single issue with it.
Unread 25-01-2012, 07:56
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
http://www.chiefdelphi.com/media/photos/36432
Our solution is shown in a photo linked above.
Richard Wallace
since 2003
Unread 25-01-2012, 10:48
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
This looks like a pretty solid design. If I understand correctly, you drilled several holes to fit each finger of the output? Also, what material did you use for the assembly?
We actually had a "hub" manufactured to mesh with the fingers of output, but this was a considerable amount of weight, and if it can be avoided, we're always up for new ideas.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 25-01-2012, 11:32
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
Anyone know where we can get one of those 74460-2249 hubs?
Unread 25-01-2012, 11:57
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
I think you are referring to this solution:
http://www.chiefdelphi.com/media/photos/36316
-Clinton-
Unread 25-01-2012, 12:07
billbo911's Avatar
-Clinton-
YES! Thanks Clinton! That is exactly where we got the idea. Follow Clinton's link for more details.
We made ours out of a scrap disk of PVC. One of our sponsors is Precision Plastics. They gave us a box of all types and sizes of scrap a couple years ago. It was just one of the items in the box. It needed a little cleaning up on the lathe but after that it was perfect.
Unread 25-01-2012, 13:13
Tom I's Avatar
AKA: Tom Indelicato
Okay awesome. Yeah in that case I'd wanna try PVC lumber, bascially a lightweight yet strong material my team has used for a number of years now with a ton of success. You can get 1x4 lengths of it at Lowes.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
