Go to Post Collaboration works. DO IT. - Travis Hoffman [more]
Unread 24-01-2012, 02:13
Physics Quiz 8
A massless spring of free length L and spring constant K is stretched until a desired force F is achieved. A mass M is attached to the stretched spring, and the spring is then allowed to accelerate the mass until the spring length is L2.
Find a closed-form solution for the speed of the mass when the spring length is L2 (where L2>L). Ignore friction and gravity. Use the solution to explore the effect of small changes in L and K (with F, M, and L2 held constant).
Unread 24-01-2012, 02:24
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: Physics Quiz 8
Energy in the system = F^2 / 2K
Length when stretched (L3) = L + F/K
Potential energy at L2 = 0.5K*(L2-L)^2
Kinetic energy @L2 = F^2 / 2K - 0.5K*(L2-L)^2
Velocity@L2 = Sqrt(2/M( (F^2 / 2K) - 0.5K*(L2-L)^2 ))
=Sqrt(2K/M( (F/K)^2 - 0.5(L2-L)^2))
I don't know what to do with that.
Unread 24-01-2012, 02:49
dan2915 dan2915 is offline
None #2915
dan2915 is an unknown quantity at this point
Re: Physics Quiz 8
I think it should be v=sqrt( F^2/(k*m)-(k/m)*(L2-L)^2).
Unread 24-01-2012, 10:42
Re: Physics Quiz 8
Did you mean F^2/(2K) ?
Unread 24-01-2012, 10:43
Re: Physics Quiz 8
Could you show your work please?
Unread 25-01-2012, 02:27
None #2915
Re: Physics Quiz 8
Sure. I used a somewhat roundabout method. Let A = F/k be the amplitude of the oscillation. The position will follow simple harmonic motion with equation x = L + A * cos(sqrt(k/m)*t), with x = 0 as the left end of the spring and the mass started at t = 0. So we set x = L2 and so L2-L = A * cos(sqrt(k/m)*t). Also, v = x' = - A * sqrt(k/m) * sin(sqrt(k/m)*t). So then we have v^2 = A^2 * (k/m) * sin^2(sqrt(k/m)*t) = (k/m) * (A^2- A^2 * cos^2(sqrt(k/m)*t)) = (k/m) * (A^2-(L2-L)^2) = ((F^2)/(k*m) - (k/m)*(L2-L)^2). Finally we have
v = sqrt((F^2)/(k*m) - (k/m)*(L2-L)^2).
Unread 25-01-2012, 09:56
Re: Physics Quiz 8
Good stuff.
In post #2, lemiant used energy conservation to find the solution*.
In post #6, dan2915 used the equations for simple harmonic motion.
Let me add a third way: use Newton's 2nd Law:
F = -k*x = M*a = M*(dV/dt) = M*(dx/dt)(dV/dx) = M*V*(dV/dx)
=> M*V*(dV/dx) = -k*x
=> V*dV = -(k/M)*x*dx
Integrate the left side from V=0 to V=V2, and the right side from x=-F/k to x=(L-L2), and solve for V2
This Quiz was inspired by post #5 in this thread.
*neglecting the error in the final step
Name:	speed at L2.png
ID:	11564  Click image for larger version
