Go to Post If they're going to blame you for it anyway, you might as well have fun. - Rick TYler [more]
Unread 25-01-2012, 10:48
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: How to attach axle to FisherPrice gearbox?
Originally Posted by billbo911 View Post
Last season we found a description of an interface here on CD and re-created it ourselves. I wish I could find the link, but no luck.
It is created by drilling a circular hole with the same diameter as the transmission output. The holes are the same diameter of each finger, or tab, on the transmission. We then drilled and tapped for a 1/2" shaft. Finally we cross drilled through the entire assembly.
We ran this through one regional, Nationals, Cal Games and MadTown and NEVER once had a single issue with it.
This looks like a pretty solid design. If I understand correctly, you drilled several holes to fit each finger of the output? Also, what material did you use for the assembly?
We actually had a "hub" manufactured to mesh with the fingers of output, but this was a considerable amount of weight, and if it can be avoided, we're always up for new ideas.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 25-01-2012, 11:32
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
Anyone know where we can get one of those 74460-2249 hubs?
