Go to Post If you're sore over the vigorous defense teams play, get over it. It happens and will continue to, as the majority of people hope. - AmyPrib [more]
Unread 25-01-2012, 11:01
Maxzillian Maxzillian is offline
AKA: Eric H.
FRC #0935 (RaileRobotics)
Maxzillian is on a distinguished road
Send a message via AIM to Maxzillian
Re: How to Remove Pinion Gear from FP-9015
Originally Posted by squirrel View Post
Another alternative is to break the pinion gear (assuming you won't need it), using a nut splitter, or even a hammer and cold chisel and an anvil. The hammer method can be hard on the motor, so use it as a last resort.
This is the method I've always used. I usually take a dremel with a cut-off wheel and cut a deep slot, nearly to the shaft, along the length of both sides of the gear (180 degrees apart). This makes it very easy to split using a hammer and chisel.
Team 935 RaileRobotics Alumni: 2001-2004
Team 935 RaileRobotics Mentor: 2009-Present
